Old 11-28-2005, 01:21 PM   #1
speeddevil456789
speeddevil456789 is on a distinguished road
Exclamation Please Help Me Out
Hi, ive had a 92 supra for four months now, ive changed all the shocks and springs and all that, also new tires, and thats about it, no rust no nothing, the only problem ive noticed that really bugs me is that at around 60 mph i start feeling vibration and also sometimes in 2nd gear, from somewhere and after i pass 60 it goes away, if i go under 60 it goes away, at first i thought it was the driveshaft, so then i put the car on stands and ran it and i noticed the driveshaft was moving, so i thought thats the problem, so i got a straight aluminum driveshaft and changed it, the 2nd gear vibration went away but the 60mph thing was still there!! but not as bad, then i did another test, i went 60 and put it in neutral still made the vibration, so it aint the tranny. im just really lost on this topic could someone please help me out. THANK YOU.
speeddevil456789 is offline   Reply With Quote
Old 11-28-2005, 09:42 PM   #2
Burn N' Up
Burn N' Up's Avatar
Have you tried balancing your rims? can you be more specific on the vibration, lopy? Or comes on fast? fast oscillation? soft or hard?
Old 11-28-2005, 11:49 PM   #3
speeddevil456789
Default Reply To Comment
Its not lopy its constant, the fast u go it gets worse acually ive noticed, and it makes a unique inside noise that cant be described. so is there anything else besides the tires that can make that noise, the differencial is not making the noise for sure. Thank you for your response.
Old 11-29-2005, 01:46 AM   #4
skunk
skunk's Avatar
do you have after market rims??
my supra did that to, not at 60, more around 100..any way it could be that your rim has play around the hub...go to your local tire store and buy some spacers, your rims will seat alot tighter, it cost me 8 bucks and solved my vibration problem.....good luck
Old 11-29-2005, 02:37 AM   #5
speeddevil456789
Stock rims sorry to say...
Old 11-29-2005, 02:59 AM   #6
Burn N' Up
Burn N' Up's Avatar
hmm, how about your wheel bearings? what makes you think it isn't the differential?
Old 11-29-2005, 03:03 AM   #7
skunk
skunk's Avatar
thats what i was going to say...wheel bearings..and maybe if your bearings were
replaced before you bought the car, who ever replaced them waited to long to do the job and actually ground the hub...it's happend to me, on my alltrac
Old 11-29-2005, 03:23 AM   #8
Unhappy
Was the drive shaft balanced?? A drive shaft out of balance will give a low 'drone' sound. Like a deep Hmmmmm.
Tires out -o- balance will usually give a vibration, but not a sound. They usually shake at around 55mph, then smooth out, then might vibrate again at a higher speed.
Old 11-29-2005, 07:23 AM   #9
ryemann32
ryemann32's Avatar
ryemann32 is on a distinguished road
drain and refill your rearend this could be your problem aswell low fluid could cause this to
ryemann32 is offline   Reply With Quote
Old 11-29-2005, 02:19 PM   #10
rnoswal
rnoswal's Avatar
Is it just at 60 mph that you notice this or is it the the same rpm range that you feel the vibration? It could be anything from the harmonic balancer on the front of the engine to the balancers in the engine to something happening to the clutch or input shaft bearing. Usually at 60 my car is pretty smooth, but I do feel the trans making a little vibration. As I rev the engine up the engine makes more vibration. Toyota put balancers in the engine to help stop that, but they had to lower the red line because of all that rotating mass. The 92 engine has those balancers.
Let us know if we are getting close!
Russ
