Old 11-13-2005, 05:53 AM   #1
1988gte
1988gte is on a distinguished road
Default trims??
Im just wondering, can anybody tell me about turbos and there trims? Also on another note just genreal info on turbos (stock, non stock, upgrade) that will work for our cars (7mgte) I looked up info in the forums but I just want to learn more
1988gte is offline   Reply With Quote
Old 11-13-2005, 07:21 AM   #2
joel w
joel w's Avatar
Default turbos..
here are some of the lingo definitions. http://www.turboneticsinc.com/glossary.htm
and some good all round turbo info...
http://www.turboneticsinc.com/faq.htm#turbosizing
dont believe what she says, size does matter..
Old 11-14-2005, 06:34 AM   #3
1988gte
very intersting. helps me alot. Turbos are different to me. Always have had v-8's "american power" the supra is FUN i love it
Old 11-14-2005, 06:47 AM   #4
joel w
joel w's Avatar
trim by the way...
i think trim is just the size of the intake wheel diameter? mine was upgraded to 50 trim and the housing was machined to fit the larger wheel..and nothing was done to the exhaust side. i guess the exhaust side mods are not needed untill higher boost levels. 50 trim is good to about 400 hp or 15psi (the sweet spot of the turbo) where it runs most efficiently....bigger hp motors need more air and or lager wheel to flow more air..
Old 11-15-2005, 05:41 AM   #5
1988gte
is 400 to the ground or flywheel?
Old 11-15-2005, 05:51 AM   #6
joel w
joel w's Avatar
probably flywheel.. but not sure..
Old 11-15-2005, 06:27 AM   #7
1988gte
but sill thats lots o power. isnt 15% a general rule in drivetrain loss? still around 340 or so to ground is alot! my mach put 281 stock. with 15% should have been 255-260ish. I think i read in a car magizine 15% was a "general rule" anybody seen or heard of this?
Old 11-15-2005, 06:51 AM   #8
joel w
joel w's Avatar
15% that sure sounds about right if i was gonna guess
also 50 trim will make 20 psi but i think that at that boost level its working it too hard and starts to create heat and? not to mention you need octane boost for higher boost and more fuel...,, just tell em what you have now as far as mods, and what boost you want to run.. and what your future plans are as far as hp and more mods... hahahha. they will help you deicide whats best for your application...
Old 11-15-2005, 04:13 PM   #9
Burn N' Up
Burn N' Up's Avatar
Where did you get your Trim and impeller mods done Joel?
Old 11-15-2005, 04:18 PM   #10
joel w
joel w's Avatar
performance techniques in cali..
www.turbonetics.com
