Old 11-03-2005, 04:10 AM   #1
ironcobra2002
ironcobra2002's Avatar
ironcobra2002 is on a distinguished road
Default like it hits a wall
hi i have an 87 supra 7mge. sometimes when in 3rd and sometimes 4th about 4-5 thousand rpm it seams as if it starts to "gag" a little like it kinda hits a wall. it has aobut 187000 on it so i figure that its probably engine wear, rings worn out maybe causeing a little blowby and robbing me of compresion but i thought i might see if maybe someone might have some other insight that might be useful.
ironcobra2002 is offline   Reply With Quote
Old 11-04-2005, 06:52 PM   #2
monkihead
SP58GT
monkihead's Avatar
does it ever do it in 5th at the same rpm? sounds like you need to replace the fuel filter...
monique- better off dead
Old 11-04-2005, 08:51 PM   #3
joel w
joel w's Avatar
whats your boost level at?
Old 11-05-2005, 04:03 AM   #4
ironcobra2002
never had it that wound out befor. always run out of road. i've already replaced the fuel filter.
if only i had the turbo to tell you the boost level.
Old 11-05-2005, 04:36 AM   #5
joel w
joel w's Avatar
ohh my bad, sorry, i feel your pain
extreme autofest hits pomona, ca - august 12, 2007 apax Off Topic Forum 1 08-10-2007 05:53 AM
