Old 11-04-2005, 06:09 PM   #11
SupraMan1784
no, injectors just spray the amount of fuel needed into teh combustion chamber, theyre controlled by a solenoid which is pretty much controlled by the ecu...without going through all the sensors and whatnot, upgrading injectors gives you more capacity...meaning it has the ability to spray more fuel in teh to chamber and you max it out as easily...it has a higher limit
Now: Saving for an MKIV
Broken Rides:
Old 11-04-2005, 10:29 PM   #12
Levi1717
Levi1717's Avatar
Levi1717 is on a distinguished road
ok thanx, i found a lexus afm for 116 i don't know if you could find one cheaper
Levi1717 is offline   Reply With Quote
Old 11-05-2005, 05:41 PM   #13
Burn N' Up
Burn N' Up's Avatar
Originally Posted by Bullz_EyE
Lexus AFM & 550cc Injectors.
I put a Lexus AFM in my 89 7MGTE and its ran like hot stinky gasoline soaked ass. Stutering and almost stalling on the line, smelled like i was pumping straight gas out the tail pipe. Now lets not forget that when i stepped on it it F*****' flew but i was getting around 10 miles to the gallon. Needless to say i pulled it. But maybe i bought a bunk Lexus one. It was for a V8 LS400. Is that what you guys have heard to drop in?
Old 11-05-2005, 08:33 PM   #14
Levi1717
Levi1717's Avatar
yah its for a lexus v8.......but u said it ran like a bat outa hell?
Old 11-08-2005, 07:29 AM   #15
Burn N' Up
Burn N' Up's Avatar
Talking
It idled like a broke dick dog walks and the gas mileage went right in the shitter but yes, it mother F'in flew.
Old 11-08-2005, 02:47 PM   #16
SupraMan1784
hahahahaha that gives me a good picture in my head...
Broken Rides:
Old 11-08-2005, 08:34 PM   #17
Levi1717
Levi1717's Avatar
sweet......how hard was it to swap on and off? could just run it when ur dragging or something
Old 11-10-2005, 05:55 PM   #18
Burn N' Up
Burn N' Up's Avatar
Absolutely you could. The AFM is held on by 3 screws and a cable. DC the battery, DC the AFM, remove the EFI fuse, let sit(i've heard as long as 6 hours but i think thats unneccesary) to let the computer reboot, and then plug everything back in with the Lexus AFM installed. WWAAAAHHHHH!!!!!
Old 11-10-2005, 07:54 PM   #19
Levi1717
Levi1717's Avatar
kick ass. i believe that next spring i may make my 87 supra a twin turbo 7m to drag wiht and drive on special acasions. with out worrying about gas milage and stuff so i believe the afm will be a good buy.
Best bang for your buck aftermarket supra parts j_moy_08 MKIII FAQ 86 01-21-2011 06:38 PM
Best Bang For Your Buck 1988 Supra turbo jordanlovesmk3 MKIII Supra 3 07-26-2009 04:37 PM
