Old 11-03-2005, 02:18 AM   #1
Levi1717
Levi1717's Avatar
Levi1717 is on a distinguished road
Default best bang for your buck in turbo
whats the first and best upgrades to start with on the 7mgte? i'm getting one from japan soon so i'm looking forward to upgrading.
Levi1717 is offline   Reply With Quote
Old 11-03-2005, 04:49 AM   #2
Bullz_EyE
Bullz_EyE's Avatar
Bullz_EyE is on a distinguished road
Replace and Repair Maintenance, a.k.a R&R Maintenance, a.k.a Corrective Maintenance. Also Preventative Maintenance. Although those may not be the best bang for the buck upgrades, in my humble opinion, that's the best place to start.
I think the best "bang for the buck" HP adder for any car is Nitrous Oxide. The other would be upgrading the exhaust starting with the Turbo Exhaust Elbow --> all the way down to the exhaust tip.
Bullz_EyE is offline   Reply With Quote
Old 11-03-2005, 07:31 AM   #3
MusicNazi525
MusicNazi525's Avatar
MusicNazi525 is on a distinguished road
which ones would you start with first... and which are the most important? Then after that... ?
1987 stock (for now) turbo 70k mi.
MusicNazi525 is offline   Reply With Quote
Old 11-03-2005, 07:34 PM   #4
SupraMan1784
SP58GT
i would go with upgrading the exhaust first...from teh downpipe, the cat, and finally the muffler, also i would replace the intake...go with either a short ram or a custom cai...i went with a custom cai, these will pretty much increase the flow into and out of hte motor, then if you want..go nitrous...but i would save my money for something more permanent than a couple shots of laughing gas
Now: Saving for an MKIV
Broken Rides:
Old 11-04-2005, 02:51 AM   #5
Levi1717
Levi1717's Avatar
after all the exhaust and intake next would u start with stuff liek boost controllers and intercoolers, or cam gears?
and thanx for the help
Old 11-04-2005, 04:30 AM   #6
Bullz_EyE
Bullz_EyE's Avatar
Lexus AFM & 550cc Injectors.
Old 11-04-2005, 04:59 AM   #7
boner1115
boner1115 is on a distinguished road
where can you buy lexus afm and 550cc injectors, and how much do they cost, and how much hp do they add.
boner1115 is offline   Reply With Quote
Old 11-04-2005, 05:17 AM   #8
Bullz_EyE
Bullz_EyE's Avatar
If you haven't learned yet, http://www.eBay.com is a wonderful place to gauge street value of parts as well as buy them. FAQ are a good place to resource information as well. The same goes with the search engine of message boards. A FAQ is where I learned a lot of things about the MkIII on my own.
Such as the Lexus AFM (or MAF). This will properly prepare your vehicle for more airflow, 25% more from what I've read. You can use this before you upgrade your injectors, but your chances of running lean and causing some type of engine destruction are pretty good. Upgrade at your discretion.
As far as HP levels, I am not familiar with gains from this vehicle yet. Someone else has to answer that. But if were to guess, 25+ from a fully upgraded exhaust, and 25+ from the AFM & injectors. Granted, your engine is in optimal operating condition.
Old 11-04-2005, 01:16 PM   #9
SupraMan1784
SP58GT
the afm meter is fine, but i wouldnt go with teh larger injectors that early... i would upgrade the injectors after getting more power...since you will need the extra fuel to burn
Broken Rides:
Old 11-04-2005, 06:00 PM   #10
Levi1717
Levi1717's Avatar
could upgrading hte injectors cause internal damage?
Best bang for your buck aftermarket supra parts j_moy_08 MKIII FAQ 86 01-21-2011 06:38 PM
Best Bang For Your Buck 1988 Supra turbo jordanlovesmk3 MKIII Supra 3 07-26-2009 04:37 PM
