Old 11-02-2005, 09:40 PM   #1
MusicNazi525
MusicNazi525's Avatar
MusicNazi525 is on a distinguished road
Question Really loud fan?
Along with the problem im having in my other post (SCRREEEEEECCCHHH), it seems to me like the fan in front of the engine or something else is way to loud. Like when im driving and i take off from a stoplight and the revvs are gettin high- i dont hear the engine revving really at all, just this loud whiney fan sound. It doesnt sound broken at all but it does seem too loud. even at low rpm's its like this. What do you guys think?
1987 stock (for now) turbo 70k mi.
MusicNazi525 is offline   Reply With Quote
Old 11-02-2005, 10:43 PM   #2
joel w
joel w's Avatar
could be a siezed or warn fan clutch?
Old 11-03-2005, 02:30 AM   #3
88Supraboy
88Supraboy's Avatar
88Supraboy is on a distinguished road
my fan clutch forze on my supra and i could hear the wind from the fan at higher RPM's and there was a lot of drag on the engine, so i got rid of the stock clutch fan and bought an electric fan, around the same price, and more HP!! it wired to runall the time (when running) and so far working very well. i would highly recommend getting rid of the stock fan.
88Supraboy is offline   Reply With Quote
Old 11-03-2005, 04:01 AM   #4
rnoswal
rnoswal's Avatar
Fan clutch.........bad.
Russ
Old 11-03-2005, 06:15 PM   #5
MusicNazi525
k im sortof a n00b so where is the fan clutch... and how should i go about removing it? (once i know where it is im pretty good at taking things apart and i got some mechanical geniouses for friends)
Old 11-08-2005, 07:52 PM   #6
have300zWantsupra
have300zWantsupra is on a distinguished road
i had a benz and in that car a loud fan noise came on, i had a bad fan alternator, and it was my aux fan kickin on
have300zWantsupra is offline   Reply With Quote
Old 11-08-2005, 09:44 PM   #7
88Supraboy
88Supraboy's Avatar
The clutch fan is on the very front of the engine, its the big plastic fan! its real easy to remove, just four nuts and its gone, the fan shroud should be removed also. you'll need to put the nuts back on to hold the pully on but you'll need some washers before the nuts.
make sure if you remove the fan that you buy an electrical fan right away so you wont over heat.
good luck!
exhaust loud wingshooter92 MKIII Supra 1 05-22-2008 02:19 AM
Loud beeping noise tannerjames MKIII Supra 0 09-07-2007 07:34 PM
loud turbo west_side_supra MKIII Supra 28 07-26-2007 09:33 PM
loud knocking Supra2NR MKIII Supra 22 07-01-2006 06:19 AM
Too loud? lifesnotfair MKIII Supra 12 12-28-2005 03:40 PM
