Old 11-01-2005, 12:14 AM   #1
88Supraboy
88Supraboy's Avatar
88Supraboy is on a distinguished road
Default trying to diesel
when i turn my 88 n/a off it will keep running for a few seconds then shut off, even with the ignition off and key out. I know overheating can cause this but its not hot at all, it will even do it when dead cold. Ive also re-checked my timming and its still around 12 degrees advanced. just wondering if anybody has experienced this or know what to fix.
Thanks Supra Lovers!!
88Supraboy is offline   Reply With Quote
Old 11-01-2005, 02:32 AM   #2
Bullz_EyE
Bullz_EyE's Avatar
That's weird. I thought dieseling was only subject to carbureted vehicles because fuel gets shut-off when the ignition is off. You may want to try a bottle or two of strong fuel system cleansers and see if problem persists.
Old 11-01-2005, 01:49 PM   #3
SupraMan1784
where are your rpms at idle? and do you hear any other noises?
Now: Saving for an MKIV
Broken Rides:
Old 11-01-2005, 02:06 PM   #4
rnoswal
rnoswal's Avatar
Sounds like a leak in the injector, or one that is not spraying right. Also there could be a lot of carbon buildup on the piston top. The combination of fuel not being burned completely and soaking the carbon on the piston could keep it running a little bit longer. The carbon stays hot and ignites the fuel even without a spark.
They make cleaners for that purpose at the parts houses, but sometimes the carbon is very hard and takes a wire brush. Just my guess though.
Russ
Old 11-01-2005, 02:44 PM   #5
supra_91
supra_91's Avatar
get some seafoam. you can find it at any auto parts place or even walmart for that matter
this stuff works really good
Old 11-01-2005, 09:19 PM   #6
Burn N' Up
Burn N' Up's Avatar
Even though it probably won't help your specific problem every car can use a good seafoaming once in awhile. seafoam is good stuff. Maybe your fuel shut off? or your fuel pressure reliefe valve? if its not dumping fuel will continue to spray for a few moments into the engine, that is all assumeing that it is hot enough to combust though....
Old 11-01-2005, 10:08 PM   #7
joel w
joel w's Avatar
agreed with the above mentioned. but also try to retard your timing back a bit, your too far advanced possably, That 12 degrees you mentioned is that with the diagnostic timing jumper installed? set it to 10 degrees with the jumper installed, you may want to pull your upper timing belt cover and double check that the cam marks are in the corect position when its TDC on #1 and the timing marks at 0
Old 11-02-2005, 04:07 AM   #8
Smile
When the key is off, the ECU stops sending signal to injectors. So...if injectors are not leaking, no residual pressure will cause fuel to enter the engine. In fact, fuel pressure should remain in the rail after engine is off.
Carbon on the piston tops will glow hot enough to light fuel vapors after key is off. Run a couple of bottles of TECHRON thru your fuel tank, as directed on the bottle. (Walmart has the best price at $5.95 ea) This is good to do every 2-3 months anyway.
If 1 or 2 injectors were sticking open a little bit, you would likely notice some running problems, and hard start, as the fuel pressure would have dropped to zero, and those cylinders would be flooded. But I doubt even 2 sticking injectors would cause "after run".
Perhaps the cold start injector, which would be the only one common to 'all' the cylinders, is stuck open a tiny bit. It would allow the fuel pressure to drop and possilbly cause your problem. The 02 would see the extra richness, and adjust the regular injectors down a bit to get the good mixture during running condition.
Keep us posted.
Old 11-03-2005, 02:20 AM   #9
88Supraboy
88Supraboy's Avatar
wow! thanks for all your ideas!! this fourm is awesome.
I dont think its carbon build up, i use cleaner very often, and probley not from heat either, it will do it if i just start it up after all night, then turn it off. I'm thinking its something to do with fuel pressure or an injector(s) but it runs fine and pulls hard (like all supras). also when i start it, it will turn over for a few seconds before starting, but not much to worry about.
and with the timing, i just used a normal timing light, and runs fine at +12, no valve knock or anything.
Thanks again everybody, its nice to have others that care about our supras as much as we do.
Citric Acid? To clean Catalytic Converters? For real? ravenmaster Non-Generation Specific Questions 11 02-13-2018 06:23 AM
diesel tuning for supras....look now corsamaan MKIII Supra 2 09-05-2007 05:25 PM
Supra is dead.... KNYFE MKIII Supra 23 11-21-2006 04:10 AM
Engine Rattle .... Help! :) roscoa1 MKIII Supra 14 05-18-2005 02:13 PM
