Old 11-18-2016, 07:22 PM   #1
supramonsta
supramonsta is on a distinguished road
Default JZA70 error code??
Hi, sorry if this is an easy one, but I am struggling to find the answer. When doing a diagnostic ecu error check, does a constantly flashing engine light (no delays in timing) mean the system is ok?
Reason being is a have a poor old girl that hasn't been started for about 9 years (yikes) and i'm trying to revive her.
on this matter, a couple of years ago I got her running briefly on engine start....but couldn't get her to run without it. So I gather spark was ok, but not sure on fuel/ On a 1JZ, whats the easiest way to check the fuel pump for operation.
Many thanks
supramonsta is offline   Reply With Quote
Old 11-21-2016, 01:38 AM   #2
Constant flashing CEL while in diagnostic mode indicates that there are no codes stored.
I'm not positive on the best way to check the fuel system operation on a 1JZ, but if it's anything like the 7M and it has a similar diagnostic port, you should be able to jump a wire from FP to B+; with the ignition key set to "Run", this provides the 12V positive power through the fuel pump circuit and you should have a constant running fuel pump until you turn the key off or remove the jumper wire.
FS : AEM EMS V2 Plug & play for JZA70 MK3 & HKS DLI JZA70 QC Parts For Sale 6 07-25-2013 03:46 PM
?'s jza70 rhd swap in a ma70? sassan MKIII Supra 1 04-01-2012 02:46 AM
Do JZA80 coilovers fit into JZA70 IRWickham MKIII Supra 1 03-22-2011 11:03 PM
*Imported* 1990 JZA70 Supra RHD 1JZ 5spd Toyotanut Buy/Sell Cars 1 01-06-2010 09:42 PM
Trailer Tow Bar/Hitch for Lexus V8 modified JZA70 Supra Phil Bradshaw Non-Generation Specific Questions 0 11-06-2005 11:31 PM
