Old 07-06-2016, 07:19 PM   #1
Yaahogge
Yaahogge is on a distinguished road
Default Rough and low idle after redlight stop.
Hello yet again allknowing supra mechanic. (hope you can handle my poor english )
Started my car and all was well, after a rather embarrassing stop due to my somewhat unforgiving cluth I wasn't able to start up again. I could hear the starter turning and the engine almost getting to start and i could also smell an abundance of fuel from the exhaust.
About an hour later and still no progress I finally had a friend come help me push it and as a last try we tried "pushstarting" it and to my suprise it actually started. However when i returned home i noticed that i ran awfully having low idle down at 4-500 rpms and sounds like not running on all cylinders (just a guess tho).
The has new sparkplug leads and sparkplugs gappad at 0.8mm (bcpr7es). It dosent really have any mods other than 3inch from the turbo and back.
I did a boost leak test the day before this and i think i managed to tighten all the leaks /
had an overboost problem right before that which i solved by fixing these boostleaks /
Also the tps was recently replaced and calibrated after tsrm.
Have annyone had this type of problem before?
gratefull for all your answears.
Yaahogge is offline   Reply With Quote
Tags
7m:rough idle:
