Old 10-27-2014, 02:04 PM   #1
amebb
amebb is on a distinguished road
Default Rear Brake Light seal
Can anyone help me please..
I need a pair of seals / gaskets for the rear brake light cluster.
The toyota part number is - 8156414610
Has anyone had any luck by making their own ???
Thanks
amebb is offline   Reply With Quote
Old 10-31-2014, 04:28 AM   #2
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Might have to use silicone. You could make a paper template from your old gasket or from the car body itself to use with what ever material you plan on using.
Old 10-31-2014, 09:25 PM   #3
amebb
Default hi
I was actually looking on ebay to see what the price of a sheet of foam gasket costs.
Its not that expensive compared to buying it from Toyota.
I think Toyota do EACH side gasket for around ?17.00 plus vat and its is despatched from Japan. so it can take time.
I think using silicon may be messy, especially when it comes to removing the rear light cluster in the future.
My advice is to use the thick matting you can get from camping shops.
A massive 6' X 3' (approx) will cost no more than ?5.00 ! A true bargain !
From that you can cut any shape gasket you require.
As added precaution, just spray silicon WD40 to waterproof it all.
I will post up pics when i do mine.
Thanks
Old 11-01-2014, 12:42 AM   #4
Bru
Bru's Avatar
WD-40 could mess with the paint.
rear main seal leak questions?? Awyman18 MKIII Supra 2 01-08-2012 05:42 AM
MKIII Wilwood 12.9" Rear Brakes With Parking Brake ARZ Arizona Performance 0 08-25-2010 06:34 PM
Brake light failure... RNEMESiS42 MKIII Supra 17 08-10-2008 12:53 AM
Spoiler Brake Light Info Bill UK MKIII Supra 0 10-27-2006 10:06 PM
