Old 10-14-2014, 09:41 PM   #1
zachariah768
zachariah768 is on a distinguished road
Default possible misfire?
Hello. I bought a 87 supra 7mgte a few months ago and I'm having an issue worth start up and idle when it's warm. It takes a while to start and wants to die at first until it gets up to idle which is 1100. Then when it warms up it idles between 5 to 7 k. I Just replaced the plugs and wires. I noticed a little pool of oil in the acordian pipe. It feels like it has a little misfire through the rpms. I've read through different forums and haven't found anyone having an issue quite like mine. Any help would be appreciated. If you need more info feel free to ask
zachariah768 is offline   Reply With Quote
Old 11-05-2014, 01:26 AM   #2
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Since you replaced the plug wires, make sure the firing order is correct. Its 163425 from left to right on the coils. Check the timing with a timing light and the car warmed up at normal idle (about 550 RPM) and with the Diagnostic block shorted T1 E1. The engine check light blinks repetitively when T1 E1 is shorted. It blinks codes when the engine is off. Basic timing with T1 E1 shorted is 10 degrees before top dead center. A little oil in the intake is normal. If it starts dripping past the air flow meter to the air filter then it indicates problems like too much blowby the piston rings or the turbo need a rebuild. If the block and head were resurfaced, then a shim gasket should have been added to get back to stock dimensions and compression ratio. You said it idles at 5 to 7 k? If that is 5,000 to 7,000, check the throttle position sensor. It may be sticking open even though the throttle plate is closed. The adjustment is detailed here. You will need a ohm meter, precision feeler gauges and a offset (S shaped) Phillips screw driver. Work with a paper towel under the TPS to catch a screw if dropped. Check the firing order first.
http://i17.photobucket.com/albums/b5...CoilPackA4.jpg
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/
Tags
1987 supra stock, 7mgte, misfire, mk3
Misfire supraguy MKIII Supra 4 08-18-2009 05:45 AM
1988 7MGE Misfire - Stumped! excaliburdj MKIII Supra 21 04-16-2008 04:56 AM
Copyright ©2000 - 2024, vBulletin Solutions, Inc.
