Old 08-02-2014, 10:25 AM   #1
haydo
haydo is on a distinguished road
Default need help urgent!
was looking into buying a 1986 ma70 but it seems to be leaking oil from an unkown spot and only running 1psi oil pressure when idling and 2psi when driving what could be causing this? and what oil pressure should it be running?
haydo is offline   Reply With Quote
Old 08-04-2014, 03:25 PM   #2
supraheelfan
supraheelfan's Avatar
supraheelfan is on a distinguished road
It could be a bad oil pressure sending unit, Maybe. OEM oil pressure readings are: at normal operating temp. and at idle oil pressure gauge should read, 4.3 psi (or a little more), at 3000 rpm it should read 36 psi-71 psi. Idk why there is such a huge gap but that's what the TSRM says. http://www.cygnusx1.net/supra/Librar...Section=LU&P=4
Also, get some degreaser and clean the bottom of the car with pressure hose and get a mechanic or somebody knowledgeable about cars to get them to try and find the oil leak, if it's only a quart every month or so you are fine. But 7mgte's are no good with low oil pressure cuz something bad will happen to the engine.
Is it the stock oil pressure gauge or aftermarket?
BTW you have a 7mge or 7mgte cuz I think the readings are meant for both engines but I'm no expert so do more research. Or maybe CRE or somebody more knowledgeable will chime in for ya.
Anyone who has never made a mistake has never tried anything new.
supraheelfan is offline   Reply With Quote
Tags
1986 supra, ma70, oil pressure
Urgent Modding Parts Help !!!! SupraHead MKIII Supra 0 01-04-2014 09:51 PM
Urgent Help Needed From You Experts krupt_01 MKIV Supra 4 02-24-2009 05:50 AM
urgent suprakid91 MKIII Supra 4 12-30-2007 06:59 PM
URGENT!! i need help from all mkiii supra owners!!!!! tone loc MKIII Supra 7 09-28-2006 02:24 AM
transmission problem URGENT HELP!!! landspeedxxx MKIII Supra 6 04-17-2006 06:13 PM
