Old 10-15-2005, 03:59 AM   #1
corewitz
corewitz is on a distinguished road
Default engines dropping when throttle depresses! help!
hey im having sort of a problem. I turn my car over and it starts nearly fine ( the engine jumps a couple times then starts) and it idles pretty normal at first. When the throttle depresses, the rpms die down to almost stalling the vehicle, and then jump back up and revs the engine. If I let it idle for a long time it slowly starts loosing idle speed.
Does anyone have a similar problem or an answer to what could be causing this?
thank you
corewitz is offline   Reply With Quote
Old 10-15-2005, 04:11 AM   #2
mrnickleye
mrnickleye's Avatar
Check for codes first.
Old 10-15-2005, 04:41 AM   #3
rnoswal
rnoswal's Avatar
Sounds like it could be your TPS, but not positive on that.
Russ
Old 10-15-2005, 05:34 AM   #4
joel w
joel w's Avatar
Default sounds like timing belt..
If that all fails, I will add these for you to check also...
becuse it sounds to me like it could be a timing belt issue? when you said.
.>>>> ****( the engine jumps a couple times then starts) ***
whens the last time the timing belt has been changed? mayby it jumped a tooth or two??? ive seen that many times.
My lower crank pully broke the collar that keeps the belt centered on the gear, so that let the belt ride off the front and shredd, luckely the bhg happened and when i pulled the cover off the belt was only 1/4 wide. but had not jumped yet.. hahahha
It also could be any number of things like maybe a plugged catolitic converter? air or fuel filter plugged? bad spark? water in your tank?
but most of these give some warning first, thats why id check the timing belt.
Old 10-15-2005, 11:41 AM   #5
nickvash0104
nickvash0104 is on a distinguished road
Perhaps one (or more) spark plugs are fouled, had that problem last week, went to accelerate, and instead of going faster, the car went slower Pulled the plugs and I guess they hadn't been changed in forever (I recently acquired the car) - all 6 were fouled out.
Black '87 N/A Auto
nickvash0104 is offline   Reply With Quote
Old 10-24-2005, 06:23 PM   #6
monkihead
SP58GT
monkihead's Avatar
check for vaccum leaks on the intake manifold or intake piping
monique- better off dead
Old 10-27-2005, 05:10 AM   #7
Clayson
Clayson is on a distinguished road
Post
well they have pritty much summed it up dont know much about the mk3s or any of them cars but hope to some day.... yeah like they said look for vacume leaks an timing belt thats is all i can say to do....
Clayson is offline   Reply With Quote
JDM 6MGE engines avilable Supra Goddess MKII Supra 12 03-27-2015 12:32 AM
lost of power at full throttle?? peedamonkee MKII Supra 4 01-08-2008 05:50 AM
Why are JDM engines available at all? finaltable Non-Generation Specific Questions 3 06-09-2007 12:51 AM
Throttle response f00g00 MKIII Supra 1 04-13-2006 12:57 AM
throttle body 87supraguy MKIII Supra 0 02-17-2006 02:40 AM
