Old 02-18-2014, 02:39 PM   #1
newageredneck
newageredneck is on a distinguished road
Lightbulb 2JZ Swap needs
So the 7mgte is coming out in favor of the 2JZ from an Aristo w/Auto transmission. I've spent several hours looking all over the interweb for info pertaining to what all is needed for the swap, and I've got most of it, but there's one problem. My '89 Turbo was made early enough to have the square cross members. Somewhere I read there is a bracket to fix that, but I've gotten nowhere with it. Also, if I'm buying the package deal with a 2JZ-GTE, including ECU, Wiring Harness, and transmission, assuming everything short of the cooling system is included, what else do I need to buy just to get the motor into the car and running?
1989 Toyota Supra Turbo
Targa-top
"Whiteout" Special Edition
newageredneck is offline   Reply With Quote
Old 02-23-2014, 06:03 PM   #2
You'll need a driveshaft to match whatever transmission you decide to use. If you're using a manual transmission you'll need a 1JZ bell housing for that transmission. You'll need a good amount of wire to extend the harness. I can't recall, but if you just use the adapters (sold by DriftMotion) instead of swapping the cross member and mounts for 89+ parts you may need a different oil pan.
Tags
2jz-gte, motor swap, swap
2jZ-GE to JDM 2JZ-GTE swap? livestrongroadie MKIV Supra 2 01-29-2012 03:18 AM
Supra mk? swap 1jgte twin turbo yanbeliveau MKIII Supra 1 11-16-2011 10:57 PM
MKIII 1JZGTE Swap How To! Pic Heavy Travis89Turbo MKIII FAQ 12 03-16-2011 05:22 PM
