Old 10-13-2005, 09:54 PM   #1
Dejvid1785
Dejvid1785 is on a distinguished road
Default How to Disable Factory Alarm?
If anybody knows how to disable the factory anti-theft system without messing up my car lemme know.
88 Targa: Exhaust, Headers, Intake
Dejvid1785 is offline   Reply With Quote
Old 10-13-2005, 10:56 PM   #2
joel w
joel w's Avatar
if the alarm is going off, you must insert the key into the door lock and lock and unlock the door, it should turn off the alarm and let you start the car. as far as disabeling it permanantly? im not sure. sorry.
Old 10-14-2005, 01:41 AM   #3
Dejvid1785
If anybody knows lemme know
Old 10-14-2005, 06:52 AM   #4
joel w
joel w's Avatar
Default pull the fuse..
why do you want to disable it??? is it not working right?? lets fix it? hahhaha
you can remove the micro switches inside to doors so it wont arm the system when you lock the door, but once someone disconects and reconnects the battery without the ignition "on" the alarm will fire off? and car wont start. there is fuse for the security system that can be pulled from the posts that ive read.?? run search on "alarm" here. also if its broke here is a helpful site
http://www.supras.com/06/techcenter/...5414c12a8f69c8
Old 10-15-2005, 01:17 AM   #5
Dejvid1785
I wanna disable it because i think this is the reason why my remote start is not working!
Old 10-15-2005, 01:47 AM   #6
joel w
joel w's Avatar
have you tried to bypass the clutch safty switch? since the clutch needs to be depressed to start? just an idea, if ita a manual that is??
Old 10-17-2005, 07:17 PM   #7
Dejvid1785
Yes i have already done that, i just need to know how to disable it permanently so my remote starter can function properly.
the right way to disable your car alarm and still be able to drive. ogkush Car Audio and Alarms 0 02-06-2007 02:04 AM
Factory Alarm dcrusupra MKIII Supra 4 11-16-2005 03:07 AM
Disabling Factory Alarm and Anti-Theft Dejvid1785 MKIII Supra 5 11-02-2005 03:51 AM
Alarm disable shendaia MKIII Supra 0 04-13-2005 07:39 PM
