Old 09-11-2013, 03:26 PM   #1
coledingman
coledingman is on a distinguished road
Default 87 mkIII n/a supra
when i let out my clutch in 1st gear is squeaks until i have the clutch all the way out...trying to find some answers it, it dosent sqeak every time but almost all the time it does.
coledingman is offline   Reply With Quote
Old 10-10-2013, 12:44 AM   #2
Squealing like a bad belt? It could very well be a bad belt. The load at lower RPM could be the cause. Try putting some dish soap on the inside of the belts and see if the sound goes away, if it does then you just need to figure out precisely which and replace the offending belt.
If it's making a swooshing and possibly lightly grinding (like sandpaper being run over something) then it's likely a bad throwout bearing or pilot bearing. Does the clutch still grab fine?
new to the mkIII supra dj_paddy89 MKIII Supra 1 12-06-2011 12:59 AM
Considering MkIII Supra for LeMons racing dp35 MKIII Supra 0 12-15-2009 06:00 AM
Considering purchasing an MKIII Supra BreakzHabit MKIII Supra 2 01-24-2006 06:48 PM
