Old 08-20-2013, 01:03 PM   #1
69ho
69ho is on a distinguished road
Default 7MGE Head Gasket Replacement
I am replacing the head gasket on my '89 Supra and noticed on re-assembly that the top surface of the rear timing cover is above the block deck surface from around the middle of the cover over to the left side and at or below the surface going the other way. This engine was rebuilt by the previous owner and it does not appear that the block deck was cut. I would expect to see this across the entire cover if the deck was cut and the cover was not installed and cut as well. I cannot find a good illustration that shows what locates the cover on the block. Maybe a dowel pin is missing? Is this normal? Where should the surface lie; at or below the block deck?
69ho is offline   Reply With Quote
Old 08-20-2013, 09:17 PM   #2
The rear timing cover MUST be cut level with the block deck. If it's cut a couple thou too far it'll probably be fine but if it sits higher you're going to find your HG leaking sooner than later. Have a machinist measure it and cut the timing plate to match.
Old 08-21-2013, 12:59 PM   #3
69ho
Can anyone tell me how the cover is located on the block? Dowel pins?
Old 08-21-2013, 09:23 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
It`s been a few years since I removed one, but I think there are 2 dowels apart from the bolts and nuts. I also remember replacing 2 gaskets and a couple of oil seals.
Old 08-21-2013, 09:36 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
Not sure but I think the oil sump is also bolted to the bottom of the rear timing case. At the time I was doing a total engine build so the sump was already removed.
Old 08-22-2013, 05:02 AM   #6
Yes, it is. This isn't something you want to remove with the head in place either... just in case someone thinks it's possible. (It is but it's a horror story and there are modifications and sacrifices which must then be made.)
Head Gasket Replacement srausaf MKIII Supra 1 07-23-2007 05:17 PM
7MGE - Stuck with changing Head Gasket??? pasupra MKIII Supra 8 07-31-2006 10:41 AM
