Old 06-22-2013, 05:09 PM   #1
pandrade
pandrade is on a distinguished road
Default is any one running a full throttle gen 2?
so bought a gen 2 to help get around the bad afm I had and its wired up but there is little to no info on this unit. all the info I found is on the maft pro or just the basic translator. I called full throttle and they basicly said "it takes 15 mins to install and tune you'll be fine" that's there response to me when asked if they had more usefull info on the fourms
if any one has one installed or has any usefull info could you please let me know
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
Old 06-23-2013, 04:48 PM   #2
What specifically are you having trouble with? The Gen II pretty much IS a PRO with just a couple features removed. Tutorials on setting up a MAF on the PRO should apply directly.... granted, yes I know, there aren't many who use a MAF with the MAFT PRO as opposed to S/D. Have you checked my site on the settings and tips and tricks? Much of the data there is equally relevant to the Gen II.
http://www.fadingworld.com/CRE/Autom...ra/Electrical/
The MAFT Gen II isn't the most user friendly system... Like its big brother its very powerful but both come with a fairly large learning curve.
7mgte stumble HELP ccguy MKIII Supra 68 04-19-2014 03:43 PM
car suddenly wont start - never ran great anyway, esp. cold, now cranks, but won't st rjSupra MKIII Supra 41 03-21-2014 05:27 PM
lost of power at full throttle?? peedamonkee MKII Supra 4 01-08-2008 05:50 AM
supra running rough finn MKIII Supra 0 09-25-2006 07:10 PM
throttle body 87supraguy MKIII Supra 0 02-17-2006 02:40 AM
