Old 03-18-2013, 04:30 PM   #1
superwhite
superwhite is on a distinguished road
Default HKS turbo timer
I installed an HKS type 1 on my 1987 Supra but the rpm indication is reading zero. The pin its connected to at the ECM is black, I checked and there is no voltage. Should there be? Did the installation manuall gude me to the wrong spot? I triple checked and everything is connected per their instructions.
superwhite is offline   Reply With Quote
Old 03-18-2013, 06:15 PM   #2
I'm not an expert on this, but i assume the timer is looking for a ground from the ignition (like most aftermarket tachometer's). If that's the case, I believe there's an IG- spot next to the diagnostic box under the hood that may work.
Old 03-19-2013, 01:14 AM   #3
Yup, you want IG- not G-. IG- runs from the igniter to the diagnostic box and to the tachometer.
Greddy Full Auto Turbo Timer w/harness for 86-92 Toyota Supra robertsws MKIII Supra 1 04-14-2009 05:43 AM
turbo timer Guest MKII Supra 5 04-05-2005 06:02 AM
