Old 10-11-2005, 01:54 PM   #1
bigal0043
bigal0043's Avatar
bigal0043 is on a distinguished road
Default Cold Start problem
Alright i have a question. In the morning or when the car hasnt run in like 5 or 6 hours plus when i try to start it.. it has a really hard time starting it turns over and seems to catch but the rpm stays at like 400 then just dies.... start it again and it will do the same thing then do it again and it will start... Any ideas???? right after i do that i can hear the waterfall behind that dash but only for a couple seconds then goes away...
sometimes when i am going and say i was going and was in gear and switch into neutral it will stall out... any ideas???
bigal0043 is offline   Reply With Quote
Old 10-11-2005, 03:21 PM   #2
rnoswal
rnoswal's Avatar
What year and model is the one you have? Miles and any aftermarket parts that might affect it too would be helpful.
Russ
Old 10-11-2005, 03:34 PM   #3
bigal0043
bigal0043's Avatar
sorry i figured i have asked alot of questions already...
1987 supra turbo
metal head gasket done like 2k miles ago
intake
intercooler hard pipes
boost controller
turbo timer
125k miles
Old 10-12-2005, 11:06 AM   #4
Cool
no blow off valve ?
the stall sounds like a blow off valve
the cold start could be a bad/clogged cold start injector
a cold start temp sensor/switch
or your egr vsv and fuel vsv .. i'd check the resistance of the egr vsv valve (under the intake manifold )
Old 10-12-2005, 02:40 PM   #5
bigal0043
bigal0043's Avatar
yea there is a bov... it is the stock one... i thought that as well but it isnt that.... i usually stall out if i am step on the gas real quick then switch to neutral... like say i back up real fast then switch to n...
how do i check the cold start injector? where is that located at?
Cold Start problem mkiiisupra MKIII Supra 1 02-22-2008 05:38 AM
Cold Start System atsomepoint Non-Generation Specific Questions 1 08-16-2007 03:31 PM
Waterfall sound on cold start! HELP! 88 MARK3 Non-Generation Specific Questions 7 06-29-2006 03:45 PM
my car only start when cold? supfoo514 MKIII Supra 3 06-04-2006 11:22 PM
