Old 09-30-2012, 07:26 PM   #1
interested!
Question cockpit brake lamp
Hi! I am having a problem with the cockpit brake ( red ) lamp , this is coming on while I am moving and braking . It goes out when moving off -handbrake released , but comes on almost every time I depress the footbrake pedal ,even lightly . The reservoir is topped up to max ,the reservoir switch works , comes on when free of the reservoir , goes out when fitted . Any ideas anyone ?. Only seems to come on when the engine is running and the brake pedal depressed -even at rest! the ABS lamp is NOT lighting up at the same time , , the pads are good , and braking in a straight line .
MKIII Wilwood 12.9" Rear Brakes With Parking Brake ARZ Arizona Performance 0 08-25-2010 06:34 PM
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
Wilwood MKIII Rear brake kit ARZ Arizona Performance 0 03-16-2007 07:46 AM
87 supra brake lights ministrytrav MKIII Supra 4 11-23-2005 08:53 PM
