Old 01-21-2013, 03:04 AM   #1
DSMeATER
DSMeATER's Avatar
DSMeATER is on a distinguished road
Default throttle pos sensor
okay, so I put in a new throttle positioning sensor today (what a pain in the ass that was) thinking that would solve all my problems...but it was really on the contrary now when the car did fire it had a high followed by a bouncing idle ... now it wont fire any ideas on what could be causing this issue?
87 supra targa t3/t4 swap 14psi, hks ssqv3, e-
cutout
DSMeATER is offline   Reply With Quote
Old 01-21-2013, 03:06 AM   #2
DSMeATER
DSMeATER's Avatar
also forgot to mention that I put in a new harmonic balancer yesterday just in case that could cause any of this
cutout
Old 01-21-2013, 08:05 PM   #3
Travis89Turbo
Travis89Turbo's Avatar
Did you adjust the tps when you installed it? If not that may be your problem, also possibly vacuum leak based off the bouncing throttle. Maybe a stuck IACV.
Start with adjusting the TPS per TSRM.
What was the problem you were trying to solve to begin with??
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 01-29-2013, 11:57 PM   #4
DSMeATER
DSMeATER's Avatar
well the car wasn't holding idle then also when I step on it in any gear higher than first after 3000 rpm it causes my engine to cut out kinda like its being limited... camshaft pos sensor maybe?
cutout
Throttle Position Sensor Jay633 MKIII Supra 3 01-19-2012 05:34 AM
Throttle Position Sensor Dan Swanson MKIII Supra 0 08-22-2009 01:58 PM
throttle postioing sensor Jeff_5_7 MKIII Supra 3 09-10-2007 10:36 AM
throttle position sensor 88turbo1 MKIII Supra 6 09-24-2005 04:51 PM
SUB THROTTLE POSITION SENSOR BYPASS TRICIA93TT MKIV Supra 0 08-26-2005 03:31 AM
