Old 12-04-2012, 04:09 PM   #1
livefastdiefun1
livefastdiefun1 is on a distinguished road
Default clutch problems.......
I bought an 87 supra mk3 N/A the other day. The previous owner told me that he drove it to where it was parked. the problem I'm having is when I got in it to start it I push the clutch, turn the key, and release the clutch pedal, only to have it stay on the floor. I pulled it up, but now it has no pressure, won't go into gear, and snaps right to the floor as soon as u touch it. Not sure why this is, and didn't want to replace the entire assembly if it might just be something simple. Any thoughts would be much appreciated
livefastdiefun1 is offline   Reply With Quote
Old 12-04-2012, 06:21 PM   #2
Leaking master or slave cylinder. Check the fluid level in the smaller white/clear reservoir between the brake booster and fender, mounted on the firewall.
Old 12-04-2012, 06:53 PM   #3
livefastdiefun1
I think its the master. No leaks from what I can see. I'm thinking maybe plunger in master is stuck. I'm replacing both master and slave.
Old 12-07-2012, 02:21 PM   #4
livefastdiefun1
Turns out it was a dead slave cylinder.
Tags
clutch, mk3, problems
Thermal Fan Clutch - 89 Turbo Supra kstewartnd MKIII Supra 0 10-04-2010 04:36 PM
Clutch kit for a 1993 JDM Toyota Supra SpRuCe Non-Generation Specific Questions 0 04-13-2009 10:20 PM
HElp with sports clutch!! whitequasimodo MKIII Supra 3 05-07-2008 11:06 PM
Clutch problems in a 88 G-string MKIII Supra 3 02-19-2007 03:48 PM
Clutch Troubleshooting ivire MKIII Supra 9 11-09-2006 01:29 AM
