Old 10-25-2012, 02:12 AM   #1
bigboy
bigboy is on a distinguished road
Default no fire
i have 88 turbo im not getting fuel or fire and i put new fuel pump in it neone know what problem could be im new at owning this car i switched over from honda to toyota
bigboy is offline   Reply With Quote
Old 10-26-2012, 10:38 AM   #2
interested!
Question No Fire
Hi! Questions ? was the car running before you changed the pump - why did you need to change it ? , is the new pump working ? ( live? - check the fuse ! ) ? , how much petrol have you got in the tank ? , did you reverse the piping when you fitted the new pump ( could be an internal blockage ! ) . Create a check list ,ticking off as you go through it .
Old 10-27-2012, 01:44 AM   #3
I've moved this thread to the MKIII Supra section where it belongs.
No fuel and no spark? Does the ECU have power (does the check engine light turn on when the ignition is turned to "ON")? Look in the MKIII FAQ section for information on checking the ECU for stored diagnostic/error codes and report back with your findings.
engine starts to fire and stops dead in its tracks?? firing order? 89supra1990 MKIII Supra 1 01-14-2011 11:51 PM
No fuel and fire Wolf13 MKIII Supra 1 11-13-2010 08:17 PM
ahhhhhh!!! fire turbonicsperformance MKIII Supra 4 06-16-2010 03:41 AM
Loss of power and electrical fire mister MKIII Supra 0 12-16-2008 10:17 PM
back fire intense 7MGTE MKIII Supra 3 09-26-2005 05:37 PM
