Old 10-02-2012, 11:58 PM   #1
Wileyk24
Wileyk24 is on a distinguished road
Default Replaced HG, still overheating???
Hey guys,
I just buttoned up my head gasket replacement for my 87 turbo. I used the toyota head gasket kit with everything from the head gasket up. I also did the timing belt/tensioner/and new water pump. I also ordered new seals for the turbo oil and water lines. In addition, I replaced the clutch fan, radiator, thermostat, and all coolant hoses etc with a silicone hose kit.
I started her up and she runs fine. Keeps good idle, maintains a normal operating temperature. I jump in and drive around the block and the temp guage shoots all the way up, we are talking less than a mile.
My lower radiator hose is very warm, which tells me my thermostat opened. The top hose is hot and has lots of pressure in it when I squeeze it.
What am I missing????
Wileyk24 is offline   Reply With Quote
Old 10-03-2012, 12:18 AM   #2
Wileyk24
FYI: Heater blows hot and no gurgling sound either...which I did have before I replaced the head gasket.
Old 10-03-2012, 04:09 AM   #3
FRISBEE
FRISBEE's Avatar
may have a trapped air bubble, let it sit, cool off and top off the fluids. also check the fan clutch.
1992 Honda Prelude 400Hp ??TQ
14.0@ 114MPH Time for Update
2007 Cadilliac Escalade daily
Old 10-04-2012, 12:18 AM   #4
Wileyk24
Fan clutch is replaced, brand new unit. I will try to top it off and see if it bubbles at all. I am at a total loss here. Going to test my thermostat as well(which is new also).
Old 10-04-2012, 02:21 PM   #5
Mishimoto
Mishimoto's Avatar
Mishimoto is on a distinguished road
Hmm See what happens after removing air from the cooling system. Perhaps a wonky temperature sender is causing this?
John Marsteller
Mishimoto Automotive
Mishimoto is offline   Reply With Quote
Old 10-04-2012, 06:56 PM   #6
Bill UK
AEM EMS
Bill UK's Avatar
Any increase in the level of the coolant expansion tank level when this happens ?
Old 10-06-2012, 02:47 PM   #7
Wileyk24
Bill I will check. I am working on the car this weekend, I remember how much was in there before it overheated, so I will see if there was any overflow.
What are you thinking?
Old 10-07-2012, 08:00 PM   #8
Wileyk24
Ok so no change in the radiator fluid level. The overflow bottle dipped slightly, less than an inch. The car is not overflowing coolant onto the ground either.
So today I decided to test the thermostat. I took it out, checked the bottom an it is a 195 degree tstat. I proceeded to boil it and with a thermometer found it wasn't opening until well after 200 degrees. Brand new unit, not functioning properly. So I went to autozone to get a new one and the system said I needed a 180 degree stat. So I bought it and took it home and boiled it. The new one open as it should and seemed to open easier than the last. Time to install.
I installed the new tstat, topped off all fluids and took her for a test drive. Good news, I made it a lot further than just one block. I actually drove all around town and on the highway. The car felt good, but my temperature gauge is settling at 3/4 the way up the temp gauge and staying there. Regardless of how I am driving.
So when the car is idling the temp gauge stays right in the middle. Once I start driving city or highway it goes up to 3/4 and stays there. Once it is up there it won't come down until I shut off the car, even at stop signs it stays up there. But once the car is off, I turn the key back on so the gauges are powered and the temp gauge sits at slightly under halfway which is perfect...
Anybody experience this before?
Old 10-10-2012, 01:00 AM   #9
Wileyk24
Still at a loss here. Went ahead and ordered new oem thermostat and temperature sensor from Toyota. Even though I had brand new autozone stuff in there already. Apparently if I can buy a thermostat brand new and have it not work, its possible the temp guage is acting up too.
I will replace both and post back my results. Still very open to ideas....
Old 10-10-2012, 04:13 AM   #10
Have you checked your ignition timing recently?
Continued overheating, coolant spewing from radiator when warming up... Da6onesupra MKIII Supra 10 02-19-2011 05:42 AM
still overheating quiky MKIV Supra 1 07-17-2009 12:11 PM
supra newb overheating vdesign MKIII Supra 13 06-27-2008 05:09 PM
82 Supra overheating suprahusker MKII Supra 2 10-17-2007 01:59 AM
2 Questions: 1 About Overheating, 1 About HeadUnit Adaptor V1P3R MKIII Supra 9 07-17-2007 05:26 AM
