Old 08-17-2012, 11:43 PM   #1
icey756
Default I need a 1.8mm MHG. Will a 1.4mm be ok?
I plan on getting a 1.4mm MHG made by titan motor sports. After I got everything back from the machine shop I added up the numbers and It came out to me needing a 1.8mm HG. Will a 1.4mm be ok or will that be too close? I want the Titan MHG because I read that its more forgiving than an HKS or Greddy. Please get back to me quickly if possible. Want to get it ordered asap. Thanks.
Old 08-18-2012, 03:05 PM   #2
icey756
Will someone please let me know. I dont want my valves to be hitting my pistons. I know it raises the compression ratio but i dont want it to raise it too much that something goes wrong
Old 08-18-2012, 06:25 PM   #3
In stock configuration, these are non-interference engines; you can have a valve fully open and the piston at the top of its stroke, and there will be no contact. Even in an interference engine, the timing would have to be off a considerable amount in order for pistons and valves to make contact. I can't say for sure, but I'm fairly confident that .4 mm will not be enough of a difference to cause contact between the pistons and valves (especially if it is timed properly).
Old 08-18-2012, 07:28 PM   #4
No it's not enough to turn the engine into an interference motor.
The real concern is the increase in the static compression ratio. If you can't find anyone with a thicker Titan MLS HG then get a Cometic MLS HG (Titan's HG appears to be a rebranded Cometic HG, by the way). If you're thinking that going with a Titan HG will let you get away with running on a still less than perfect block and/or head I've got bad news for you though.... While they're both more forgiving they're still not going to live long on a warped, pitted, scratched or coarse deck.
I would look for either a 1.8mm or a 2mm Cometic.
Old 08-19-2012, 12:24 AM   #5
icey756
I found a site that had cometic gasket and when i was reading their little article I saw that they recamend going .5mm over your bore size even on stock bore sizes. Is that really suppose to be safer? heres the link. It says this stuff at the bottom. http://www.raceeng.com/techsheets/cometic.pdf
Old 08-19-2012, 03:24 AM   #6
The HG is always bored out a little higher than the cylinder... even new. Going too big isn't good though either. Has you block been bored? If not 84mm is what you want.
Old 10-15-2012, 02:15 AM   #7
icey756
No my block is not bored. I found this one on ebay. Let me know what you think.
http://www.ebay.com/itm/270890709376...84.m1423.l2649
Old 10-17-2012, 12:23 PM   #8
i payed 240$ for a 1.3mm mls cometic recently.
add up the shipping to the cost it may be worth it to just get it from a local auto parts store.
Old 10-19-2012, 01:36 AM   #9
907mge
907mge's Avatar
Supra store has the titan 1.4mm MHG for $119. If what cre says is true it should be the same as a cometic.
Old 10-19-2012, 04:33 AM   #10
Has anyone dealt with Suprastore in the past five years? I'd like to see some actual feedback to know if they've cleaned up their act or not.
Cometic and Titan are visually the same. I've spoken to two store owners who would neither confirm or deny that the two are the same but both agreed that "yes they seem the same". I think the Titan are shipped in bulk packaging where the Cometic have a branded package. The Cometic are available in more sizes, IIRC.
Tags
headgasket, mhg
