Old 05-25-2012, 08:43 PM   #1
mt17249
mt17249 is on a distinguished road
Default How to tell the difference between cams
I am rebuilding a 7M-GTE. When i removed the cams, there was a large amount of scoring on the cams and bearing journals. I found a remanufactured head with cams for $400. I purchased it and am not sure if the cams that are in it are from the GE or the GTE. Does anyone know how to tell the difference between them? What the duration specs are and a easy way to measure it? Are there any markings on the cams to look for? Any help would be appreciated!! Thanks!!
mt17249 is offline   Reply With Quote
Old 05-26-2012, 01:59 AM   #2
The exhaust cam is the same for both the GE and the GTE. Off hand I can't tell you of any quick and easy way to identify the intake cam. Someone over at Supramania.com profiled the stock 7M-GTE some time ago, might try searching for the thread over there.
Old 05-30-2012, 03:18 AM   #3
http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=48
if the intake cam is different, then the tsrm might have numbers to inspect sizes.
EDIT: and by "might" i mean all the sizes are in the link i shared. LOL
Old 06-28-2012, 04:29 AM   #4
was looking for some info and found more info on this topic.
http://www.cygnusx1.net/Supra/Librar...l.aspx?S=A&P=4
Old 06-28-2012, 05:31 AM   #5
I've looked those over before but it's not too helpful... You may just have a cam which is worn beyond spec and simply requires a thicker shim. So it could look like a GE cam but just be a worn down GTE cam which you could still use with some Yamaha shims.
Old 06-28-2012, 05:41 AM   #6
i really like how 5mges have no shims
1987 7mge cams rowdytrw MKIII Supra 3 01-22-2010 09:04 PM
NA cams in a 7mgTe? the ghoul MKIII Supra 19 10-03-2007 01:58 AM
7mge cams mk3000 MKIII Supra 0 09-12-2007 08:28 PM
head difference? mizuboi MKIII Supra 1 01-06-2007 11:14 PM
Looking for good adjustable cams SupraSaver87 Non-Generation Specific Questions 3 08-05-2006 08:43 PM
