Old 05-08-2012, 02:32 AM   #1
sd88supra
Question Tail light schematics?
My right tail light is much dimmer than the right; when I brake, the right tail light dims completely and the left tail light brightens up as it should.
Sure enough, it happened after some heavy rain. I also noticed the dash lights and headlights flicker along with the engine speed at idle. Is this bad plug wires or alternator issue?
Anyone know where I can find wiring schematics? Already got pulled over leaving the bars (wasn't drunk enough, thankfully).
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
Old 05-08-2012, 04:04 PM   #2
seals around the taillights are known to leak.. could have some water in there causing a short.. Peal it off dry it out.. Did you perhaps change the bulb? You have power so its a voltage issue..
as for flickering lights id check your alt first.
Old 05-12-2012, 07:37 PM   #3
sd88supra
Yes, I changed the bulb, nothing changed. I think I'll just take the whole thing apart and see what I find.
Old 05-13-2012, 02:01 AM   #4
Busted Knuckles
Busted Knuckles's Avatar
I had a similar problem with my '88. One bulb was dimmer than the other four for both the tail light and brake light. After looking at the tail lights and the wire connections, I noticed the grounding wire, screwed together with the bulb holder, was corroded. I sanded the corrosion off both the bulb holder lug and wire connector, then re-assembled it with plenty of dielectric grease on the lug and connector. It's been good for two years now.
Old 05-13-2012, 02:37 PM   #5
good stuff.. probably the issue
Tail Light Questions suprajsac MKIII Supra 3 12-13-2008 01:12 PM
tail light Subjug4tor MKIII Supra 5 05-03-2008 03:41 AM
Grounds for the left tail light supraman121 MKIII Supra 1 11-08-2007 12:57 AM
Tail Light Changing? newbsupra MKIII Supra 2 05-21-2006 04:07 PM
