Old 04-26-2012, 09:39 AM   #1
Cyto
Cyto's Avatar
Cyto is on a distinguished road
Default Gauge cluster, overdrive, power everything no worky?
Umm.. lol I think something is wrong.
The only gauges that work are the fuel, and speedo -probably because those arent connected to the circuit?
My temp, boost, RPM, oil pressure gauges do not work, nor does anything light up.
My power windows do not work, the lumbar support doesn't work.
OH YEAH... The freakin thing wont even go into O/D now. Probably because of a reliance on a signal from something that is connected to whatever the problem might be.
Any ideas?
Proud owner of a 1988 Toyota Supra Turbo, 105k Miles, and great condition.
I might have to sell it to help pay for school so here's the link.
http://www.toyota-supra.info/forums/...html#post72357
Cyto is offline   Reply With Quote
Old 04-26-2012, 12:04 PM   #2
Green7mgte
Supra Forum Moderator
could be looking at a bad ground.. Id check those first.
I was trying to dig up the post that described were they were for the clusters but for the life of me I cant find it.. I know it was only a few days ago too.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 04-26-2012, 05:17 PM   #3
Have you checked the 7.5A Gauge fuse yet?
Old 05-01-2012, 07:42 AM   #4
Cyto
Cyto's Avatar
Yeah Cre, I did.. That was it, and the first thing I checked..
Old 06-19-2012, 07:11 AM   #5
Nassol562
Nassol562's Avatar
Nassol562 is on a distinguished road
where can i get a 7.5 fuse i have a 15 fuse in there.... does it matter or do i need a 7.5
Nassol562 is offline   Reply With Quote
Old 06-20-2012, 04:37 PM   #6
A fuse is protection. If you use one which doesn't blow BEFORE the part it's protecting than the part will probably burn up long before the fuse if there's a short or surge.... in which case why even bother putting a fuse in? You've already defeated the purpose.
Cyto, did you ever get this worked out? What was the issue? I'm pretty sure O/D requires an engine speed signal. If it gets that from the tach then that would explain the loss of that feature.
Aftermarket gauge cluster? djblanco MKIII Supra 2 09-26-2011 02:15 AM
Gauge Cluster Differences btwilson86 MKIII Supra 3 06-11-2011 02:05 PM
Quick newb gauge cluster question Calm Like A Bomb MKII Supra 4 08-20-2009 08:55 PM
Greetings! importauto Import Auto Center 7 06-21-2009 07:42 AM
Gauge cluster dcrusupra MKIII Supra 2 11-16-2005 11:55 PM
