Old 04-19-2012, 02:12 AM   #1
Awyman18
Awyman18 is on a distinguished road
Default tuning with apexi 5 knob AFC
Like the title says, im inquiring about tuning with the 5 knob apexi like this one
SO, just curious on install, i kno ill need a wide band, which isnt a problem, and how hard/easy is the tuning and do i need a laptop to see wat im doing? lol
Awyman18 is offline   Reply With Quote
Old 04-19-2012, 08:08 AM   #2
Honestly, as basic as that unit is I would take the car to a shop and get it tuned for $100-$150. It shouldn't cost much as it hasn't got even half the flexibility and features of the model that followed it. Install is yourself, zero out the dials and your car should run as if it isn't even there. Then get it tuned and save money.
It's not a difficult setup to tune though but yes, you need a laptop and you need a wideband with data logging functionality. You could do it on the fly with someone else driving and you staring back and forth frantically between the tach and the the O2 gauge but on the dyno they'll be able to dial it in much tighter than you will without a more sophisticated setup.
Old 04-19-2012, 01:11 PM   #3
Awyman18
lol dyno shop it is, ive heard it has same BASIC tuning capabilities as the neo, but the neo u can save different tunes and such i believe? I might be off, but i got this thing for $60 with harness.......and i was looking for a baseline tune so why not lol
Old 04-19-2012, 07:09 PM   #4
Um, not quite... That's like comparing a pad of paper to a laptop. The original SAFC, while very reliable, is very limited. What are you hoping to get out of it? Do you have any mods which need it?
Old 04-20-2012, 01:40 PM   #5
Awyman18
yea i have some bolt ons but no injectors, lex maf nothing like that. But i kno a good tune will give me some hp, and i kno im probably running a little lean
Old 04-21-2012, 09:21 AM   #6
Lean? Not likely. The ECU's fuel maps cover a much higher volumetric efficiency than you'll see with just basic bolt ons and added boost. It's not until you begin tampering with the whole equation, the bigger picture that you really need to worry about running lean. More often than not you find that you're actually still rich and need fuel pulled for better performance... If it is lean it's probably time to replace the fuel pump, filter and get the injectors serviced. Do let us know how it turns out though.
Tuning Jay633 MKIII Supra 7 04-16-2012 01:20 PM
Apexi Power Intake for N/A MKIII OdysseusOnWheels MKIII Supra 5 06-10-2011 06:51 PM
Apexi SAFC 1st gen Tuning?? Conga1991 MKIII Supra 0 03-31-2011 01:19 PM
Is there anywhere that does ecu map tuning??? marcmann982 MKIII Supra 1 01-04-2011 05:17 PM
ANY ONE EVERY USE A Apexi Boost Controller donutking MKIII Supra 1 10-07-2005 01:58 PM
