Old 04-14-2012, 01:18 AM   #1
pandrade
pandrade is on a distinguished road
Default rack and pinion converson
after a few google pages of randome clicking i fould out this website from the ukrain every tab from engine to suspension had a little somthing i dident know
http://www.mk3ukr-supra.net/home.htm
found alot of its info helpfull but one thing cought my eye above all
he says that people would convert the mk3's rack and pinion to that one of an rx7 or a mustang, i would imagine the only reson for this is for better steering respone. on his suspenson tab at the bottom he cover this but what i would like to know is how much truth there is to this and how practical would this be?
any thoughts
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
Old 04-14-2012, 05:13 AM   #2
I wouldn't say the mustang rack was any better.... cheaper to service, a couple more option (as far as gearing) and it's a manual steering rack, not power so it's a bit lighter. There aren't a lot of people who've done it. I've never heard of any model RX-7 rack being swapped in. I like the progressive power steering found in later MKIII's. I find the lesser assistance at higher speeds I find highly agreeable (less likely to fly into oncoming traffic when you sneeze at 90MPH).
I see that he switched out the bumper support for a light weight aluminum bar.... I had always wondered if I could fine one close enough in size to swap onto my MKIII with little effort.
Old 04-15-2012, 01:34 AM   #3
pandrade
so as of steering doesent really do much diffrent, more of a waight reducton messure right
Old 04-15-2012, 02:37 AM   #4
How the steering is geared does make a difference and can be adjusted in almost any system. The weight reduction isn't anything to write home about though when you're talking about giving up the assistance in a 3500lb beast. In a Miata, sure, why not... Not a huge difference once you hit 5MPH.
Old 04-15-2012, 06:50 PM   #5
Ranma
Ranma's Avatar
NOt sure why people want to mutate Supras? If you want a Chevy, Ford or whatever buy it. With the steering system you take a chance of making the fatal mistake. The one that will remove you from the gene pool. There are lots of Mustangs on the market. I see them abandoned on the side of I 44 on the way to work.
As young people you take your chances. I see replacing components from other cars is dangerous at best. There are those of you that can do a good job but nature always sides with the hidden flaw.
Old 04-15-2012, 08:31 PM   #6
pandrade
I wouldn't really butcher my mk3 for a litltle more options. I would like to make my steering more accurate/responsive. I read how to take the excessive slack out on the FAQ's but I would like to go a little further.
Any suggestions
Old 04-16-2012, 01:55 PM   #7
i have always favored the great handling of these cars. no matter how fast your going just keep turning, it will go there...
Any tips on replacing Rack & Pinion on 86 1/2 Supra Norm MKIII Supra 4 08-13-2011 02:52 PM
Fixed Rack and Pinion but steering still does not work 91supraturbobrown MKIII Supra 3 03-29-2011 04:22 AM
Need Rack and Pinion steering unit Ranma MKIII Supra 1 08-11-2010 06:44 PM
Rack and pinion removal fasteddy5000 MKIII Supra 2 04-05-2010 02:16 PM
rack and pinion question ebang MKIII Supra 1 02-13-2007 09:25 PM
