Old 04-05-2012, 01:08 AM   #1
1jsupra
1jsupra is on a distinguished road
Question ???? power steering problem ??? help
can any one help i bought a new power steering rack n pump and i still dont have any power steering what can be the problem but i do hear a whiny nosie
1jsupra is offline   Reply With Quote
Old 04-05-2012, 02:41 AM   #2
Joefishizzle
Joefishizzle is on a distinguished road
I would double check all your lines. Also make sure you have the low pressure and high pressure lines connected in the right spot. And could be your pump is bad if your hearing a whinning. Did you run the pump without fluid for a little?
Joefishizzle is offline   Reply With Quote
Old 04-05-2012, 02:44 AM   #3
1jsupra
i have to check on the lines but yea its a new pump
Old 04-05-2012, 02:54 AM   #4
1jsupra
where can i find a diagram with the power steering lines
Old 04-05-2012, 02:57 AM   #5
Joefishizzle
Ya double check that, also make sure your shaft is connected correctly. Are you running the correct fluid?
Old 04-05-2012, 03:18 AM   #6
http://www.cygnusx1.net/Supra/Librar...ection=SR&P=36
If you have progressive power steering (an option on '89 and later models) the pressure control valve or related parts may be bad. It's a valve used to alternate just how much pressure the power steering system contributes.
I am more inclined to believe that you didn't prime the new rack and pump properly and have a fair amount of air trapped in the system.
Old 04-05-2012, 08:59 PM   #7
essial
essial is on a distinguished road
When I had a huge power steering leak I noticed that the thing was quiet (and non functioning) when there was absolutely no fluid in it. Quiet when it was full (the few minutes before it all ran out), and loud as hell when it was almost empty. I'd say first guess is, as mentioned above, you have lots of air in the system. Is your steering fluid level going down as you rock your wheel full left to full right? When I first put fluid in it would make that horrible metalic whining sound (louder if I pushed harder, almost quiet when I let go) until I rocked my wheel full left and right and got all the air out of the system. Just a guess.
essial is offline   Reply With Quote
Power steering hose problem? supradestro MKIII Supra 10 08-17-2011 03:55 AM
Power Steering Pressure Hose Step by Step SilverMK3 MKIII FAQ 1 02-20-2011 09:38 PM
Power steering problem chinesedawn MKIII Supra 0 02-14-2010 11:20 PM
Power steering problem JOEYP3RD Non-Generation Specific Questions 1 06-05-2009 05:19 AM
power steering problem 3.0trd MKIII Supra 12 06-24-2008 01:17 PM
