Old 03-28-2012, 07:28 AM   #1
SweSupra
SweSupra is on a distinguished road
Exclamation Oil pressure warning, but got pressure?
Hello!
Iv got this problem, it doesn't feel good driving with it.
So after a minute or so after starting the engine cold, the oil lamp shows up
and stays on untill i kill the engine.
However the oil pressure is good, if i can trust the original pressure gauge?
Shouldn't those two work together or is it two separate systems?
And there is one thing too! Im not 100% sure that i got the right oil stick, i fear its to short, cuz there is on that is shorter right?
Im sure i filled the right amount of oil at last change and it just showed up on the bottom of the stick
/ SweSupra
SweSupra is offline   Reply With Quote
Old 03-28-2012, 01:41 PM   #2
SweSupra
Maybe someone with at -91-92 supra can go out an measure the oil stick for me?
/SweSupra
Old 03-28-2012, 08:39 PM   #3
You need to specify which engine you have. The measurements for 7M-GE, 7M-GTE, 1G-GTE and 1JZ-GTE are all going to differ, I'm sure. If it is a 7M, those measurements have been posted and you should be able to find them is you search the forum a little. If it's a 1JZ or 1G there are very few owners of such vehicles here... If you can find out who they are you may want to try sending them a PM directly.
Power Steering Pressure Hose Step by Step SilverMK3 MKIII FAQ 1 02-20-2011 09:38 PM
7MGE oil pressure problems I h8 Hondas MKIII Supra 18 07-18-2010 06:27 PM
Oil Pressure? supraguy MKIII Supra 3 09-16-2009 08:35 PM
7MGE oil pressure Arne (Denmark) MKIII Supra 14 07-31-2009 10:07 PM
