Old 02-22-2012, 05:05 AM   #1
Sonyps307
Default Cam seals leaking
Ok so I had a bhg so I replaced it with a new Toyota head gasket and I ordered a new reman head with a new parts. Got the car running just to find out that the cam seals r leaking. Also when I'm driving it around it sprays oil all over my motor and hood could a cam seal do all this. Also my upper timing belt cover is off.
Old 02-22-2012, 04:50 PM   #2
MJG
MJG's Avatar
Leaking cam seals with the cam gear cover removed, exposing the area to fan wash, could cause oil to be sprayed through out the engine bay.
Since you will be replacing the cam seals, I suggest you replace the cam cover seals and the cover screw seals as well.
Old 02-22-2012, 04:57 PM   #3
Sonyps307
Well since my heads was new it did have cam seal installed yet and I didn't catch that so right now I have no cam seals. Does the the 7m have rear cam seals
Old 02-22-2012, 05:21 PM   #4
MJG
MJG's Avatar
No, just the seal behind the cam gears.
turbo or valve seals? blowing smoke bbullsj MKIII Supra 2 06-16-2011 07:33 PM
Leaking oil mauimale5799 MKIII Supra 4 01-18-2011 04:26 AM
Oil Is Leaking I Have Pics!! Need Help!! Ahmad88 Non-Generation Specific Questions 18 07-09-2006 03:56 PM
Front Main Seals nickvash0104 MKIII Supra 5 01-08-2006 06:48 AM
Valve Stem Oil Seals Roger UK MKIII Supra 1 10-17-2005 01:24 PM
