Old 01-08-2012, 12:12 AM   #1
Awyman18
Default rear main seal leak questions??
ok so my 1990 supra turbo has a rear main seal leak. Its not awful...like a couple drips usually...also my 1992 toyota camry leaked from the rear main seal, but only during the winter time like my supra. Is this a toyota thing or just old seal thing? lol also, in the summer ur seals swell and such, and in the winter they shrink, think its only a winter thing considering its effing cold here? And last question is could a bad pcv valve be the issue? Or bad pcv= exess pressure + cold weather (seal shrinkage) = minor oil leak? Not a big deal if i have to change the seal, but if its something minor id rather do that instead of dropping the tranny and such
Old 01-08-2012, 02:48 AM   #2
No, it's not a Toyota thing... It's a 20+ year old car thing. Yes, the seal is most definitely on it's way out. A blocked PCV system may contribute but the amount of pressure that would be required to blow the seal would present far more severe symptoms elsewhere. The leak increasing in volume when cold is typical.
Old 01-08-2012, 05:42 AM   #3
Awyman18
ok just wondering lol i mean yea i plan on changing the pcv valve anyways, and probably this coming up spring ill change the rear main seal, depending on if the leak is still there or watever. thanks boss
leaking engine Ranma MKIII Supra 40 11-09-2010 03:18 PM
1987 MK III M7 GTE Oil Pump Seal replacement and other questions? professorbob MKIII Supra 0 06-09-2010 01:10 AM
Replacing rear pinion seal bmc52387 MKIII Supra 1 10-18-2008 11:13 AM
Rear Main Seal mkiiisupra MKIII Supra 3 09-28-2007 02:31 PM
rear seal blown frankie_lala MKIII Supra 2 09-02-2005 06:12 AM
