Old 12-28-2011, 10:39 PM   #1
carl johansson
carl johansson is on a distinguished road
Default ARP connecting rod bolts - same for NA or Turbo?
I am putting ARP connecting rod bolts in mt 88 7MGE. I check summit racing, they only list for a MGTE, I call ARP - and they do not have that engine listed. Anyone know for sure if the turbo application will fit the 7MGE - for sure, not guessing?
thanks
Carl Johansson
carl johansson is offline   Reply With Quote
Old 12-29-2011, 01:02 AM   #2
Good lord... pretty much EVERY post in the MKIII forum has me as the last person to respond... I need to get away for a while. (Granted, a lot of those are because I've been moving threads from other forums to this one and I've just posted indicating as much...)
Anyway, back to your question.... YES, they use the same fasteners. When in doubt check the part numbers for the OEM components with your local dealer or the EPC. All 7M's use 13265-42010.
Even if ARP had a different set for the GE the GTE would undoubtedly be the more robust option... so you can buy with confidence.
Old 12-29-2011, 03:32 PM   #3
carl johansson
Thanks cre,
your help is invaluable to us - not Un Valuable !
1991 Supra Turbo Charge Connecting Rod Torque Spec. alving1010 MKIII Supra 0 07-19-2010 11:29 PM
turbo bolts suprakid91 MKIII Supra 3 05-17-2008 06:10 PM
