Old 12-20-2011, 03:28 AM   #1
Killa B
Killa B's Avatar
Killa B is on a distinguished road
Red face slugish before op-temp
i have recently rebuild my 7mge, i have noticed it takes it about 15-20 minutes to reach op-temp. The engine runs really slugish when i drive it under op temp almost like ive lost 40% power its fine if its at op temp though. Also if it hasnt reached op temp and i turn the heat on it cools the engine down pretty quick i figured that was normal because its an older car. Im using Valvoline max life 10-W30 oil in it. does anyone know what could cause this. Is it just the engine hasnt broke in well enough yet?
1989 na turbo supra ~ 3ARacing exhaust 2.5" pipe no resinator, sports package
Killa B is offline   Reply With Quote
Old 12-20-2011, 07:12 PM   #2
Test the AFM, ECU temp sensor, make sure the cold start injector isn't leaking and verify that both mechanical and ignition timing are set correctly.
Old 12-20-2011, 11:28 PM   #3
Killa B
Killa B's Avatar
where is the ecu temp sensor located?
Old 12-21-2011, 12:10 AM   #4
There's a nice graphic in a post on the temp sensor located in the FAQ section.
Old 12-21-2011, 01:28 AM   #5
87hilux7mge
87hilux7mge's Avatar
first time ive heard of an over efficient cooling system with these cars. wondering if the thermostat is stuck open, at least as part of the problem.
sounds alot like a timing issue though. follow the aforementioned advice.
Old 12-25-2011, 03:12 AM   #6
Killa B
Killa B's Avatar
Talking
okay so i apologize i probably should have said something about oil leaking only on exhaust side. Turns out i didnt tighten up the 3 plugs in the block. Tightened them down and its A LOT better motor even sounds more healthy. hope this can help someone in the future.
Old 12-25-2011, 06:59 PM   #7
87hilux7mge
Little details man, glad u got it sorted tho. If anything new comes up, let is know.
High speeds for 15min or longer, temp gets high rob87 MKIII Supra 18 06-30-2010 06:50 PM
Water temp gauge dead Fredde MKIII Supra 4 05-27-2008 12:40 AM
strange temp gauge activity D_Train MKIII Supra 21 08-25-2007 05:43 PM
Coolant temp sensor thread size?? petey turbo MKIII Supra 5 02-12-2007 06:15 PM
Temp. Sender-what does it do? Benesesso MKIII Supra 2 05-10-2006 03:06 AM
