Old 12-10-2011, 09:55 PM   #1
graywolf1969
graywolf1969 is on a distinguished road
Default help heat problem
ok so today when i got in my supra let it warm up for a bit then started to drive down the road my heat was not as hot as it should be so i went down town its 10mi away and i had poor heat so i pull over and look at the line that go's to the heater Val it's by the ABS thing on the right side of the car the passenger side it was still hook up, So if i don't go any were and it just sets and idel and it stay hot but not like it use too but if you give it gas why it's in idel it stats to go cold, but it's not like cold it's just warm ok so could this be the fan because i think it has a clutch in the fan or is it the climate control I don't know and I need to get the heat back thank you all
graywolf1969 is offline   Reply With Quote
Old 12-11-2011, 12:10 AM   #2
I would start with the fan clutch. An issue with the mixer or intermittent failure of the HCV's VSV aren't out of the question either.
87 MK III turbo - AC & Heat Always On Problem robfab MKII Supra 0 08-04-2008 07:12 PM
Heat Consistancy Issues Chambers MKIII Supra 14 04-07-2008 12:52 AM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
Heat?? burton51m MKIII Supra 11 02-25-2007 04:28 PM
