-   -   Valves ticking (http://www.toyota-supra.info/forums/mkiii-supra/19978-valves-ticking.html)
Semper_Fi 11-27-2011 04:10 AM
Valves ticking
Hey. Thank you for showing intrest in my thread. Im currently in the final process of my reconstruction of my project. I rebuilt the engine, and when i turned it on for the first time, the engine sounds amazing, then i installed the intercooler piping, and now the head has a strange ticking sound... Just wondering if it could be that the gas is older, oil psi, or simply the valves need to be readjusted... Before i rip the engine apart... in 7 hrs, please save me the trouble. Thanks again supra forum.
Pfc Carlos
87hilux7mge 11-27-2011 04:53 AM
sounds like it could be low oil pressure, or valves need reshimmed. that the only things that come to mind right now, tho i am sick and tired as hell..
Semper_Fi 11-27-2011 05:11 AM
Well... i hope not low oil pressure... because then i need to remove the oil pan and rip it apart again... So ill check the valves, and keep youall updated... Thanks again!!!
cre 11-27-2011 09:38 PM
The stock injectors are pretty loud too. It's more noticeable with some sets than others and the last set I had serviced came back even louder than when they left. Use a stethoscope to see where the noise is originating from.
