Old 11-24-2011, 02:08 PM   #1
tom917
tom917 is on a distinguished road
Default Supra Electrical system
I have a 1986 supra.
for some reason my battery keeps running down, I feel that is may be my factory installed alarm system can anyone tell me how to turn it off?
Thank you
Tom
tom917 is offline   Reply With Quote
Old 12-27-2011, 08:01 PM   #2
You posted this in the wrong section... hence it went unseen. Thread moved to the MKIII section.
The factory installed security system is VERY low power. Unless something is significantly wrong with it or it is frequently triggered it is very unlikely to be the cause of the problem. Google how to test for "parasitic loss" with a multimeter and start pulling fuses one at a time until the draw is under a hundred milliamps (around 30 or 40mA is the recommended limit). If it already is then get the battery tested.
Poorly installed aftermarket components are the most common causes of excessive drain: Stereo, amplifier(s), radar detectors, accessories connected to the cigarette lighter (if the cig lighter has been rewired to stay powered when the ignition is off), hard wired radar detectors, etc.
1985 Supra electrical problems ssaskiksubucni MKII Supra 1 06-10-2006 04:01 AM
Im New, Going from a V8 to a supra maybe? Help! Deadtoday Non-Generation Specific Questions 9 05-24-2005 11:10 PM
disarming factory antitheft system 89 supra cacarolturbo Non-Generation Specific Questions 2 05-22-2005 11:15 AM
