Old 11-08-2011, 10:17 PM   #1
Sonyps307
Default Battery overcharging
Ok so my Alternator went out on me so I replaced it yesterday. So then today when I was coming home from work I was getting on the highway I punched it then my volts Meter shot up to 18 volts the come down when I let off. Need help I had the alternator and battery tested all it good.
Old 11-09-2011, 12:42 AM   #2
Sonyps307
It only goes up to 18 volts when the car is up in hight RPMs like after 4,000rpms
Old 11-09-2011, 01:43 AM   #3
Busted Knuckles
Busted Knuckles's Avatar
The rebuilt alternator has a bad regulator. I had the same problem with a reman alternator in my wife's Celica. Take it back and make them replace it. The tester obviously doesn't rev the alternator up enough to trigger the fault.
PLEASE HELP ME!! Supra battery :( SquamishSupra MKIII Supra 6 10-18-2009 03:39 PM
what a loose battery ground clamp does ghost88 Non-Generation Specific Questions 0 02-25-2009 04:42 AM
Battery Upkeep mrnickleye Supra FAQ 0 02-21-2007 03:30 AM
wiring short drains battery misupra MKIII Supra 13 09-15-2006 04:55 AM
new battery no start mosupra87 MKIII Supra 1 03-23-2006 08:16 PM
