Old 11-06-2011, 01:47 PM   #1
supraman8188
supraman8188's Avatar
supraman8188 is on a distinguished road
Question Air flow meter swap for N/A
What exactly needs to be done to successfully swap the afm from the SC400 to a MKIII N/A? 550 injectors as well..?
Supe supe!
1986.5 Supra Manual Red Mica(Maroon) w/wing: Custom sound system, 18" Tork Revos, smoked tail lights, markers, and turn signals.
Mods: Eibach lowering springs, Energy poly front upper and lower control arm bushings, custom cold air intake, solid engine mounts, Magnaflow, short shifter, Optima Red Top, other custom fabrications..and yes a bra.
supraman8188 is offline   Reply With Quote
Old 11-06-2011, 08:16 PM   #2
This mod doen't work on the N/A. The 7M-GE uses a completely different type of ECU. You'd need to install a MAFT Pro in order to do this, but in that case you might as well go with a GM MAF (This can also be done with a MAFT Gen II.) or a speed/density (MAP) setup.
car runs better without air flow meter?!?! wtf 89supra1990 MKIII Supra 3 03-29-2011 07:00 PM
Lexus air flow meter swap? supracurtis MKIII Supra 3 02-14-2009 12:47 PM
mass air flow meter shaggymx3 Non-Generation Specific Questions 0 06-13-2006 10:45 PM
air flow meter conversion mrmoo Non-Generation Specific Questions 0 07-02-2005 11:38 PM
