Old 10-09-2011, 05:10 PM   #1
hbski
hbski is on a distinguished road
Default rear subframe mounts
installing my subframe, i notice that the top "cap" of the bushing does not tighten to the body.is this the way it's suposed to be? they are pretty worn.and ,is there a simple solution to fix this?possibly a spacer?
hbski is offline   Reply With Quote
Old 10-10-2011, 03:49 PM   #2
hbski
ah,it's supposed to be floating.i can't find anything in the tsrm for tolerance.i found the bic spacers,but i am curious if someone has utilized the stock rubber and just shimmed between the subframe and body?
thanks
Rear Speaker Replacement batmmannn MKIII Supra 0 06-07-2010 04:58 AM
rear subframe aaron_arthur MKIII Supra 1 07-19-2008 02:40 AM
Need help with differential mounts!! Bone_Stock_Supra MKIV Supra 1 04-11-2008 03:54 AM
