Old 10-05-2011, 04:30 AM   #1
Killa B
Killa B's Avatar
Killa B is on a distinguished road
Post heat temp gauge flipped?
I couldn't find a post similar to what mine is doing soo, i havent started my engine at all since i rebuilt it i know there might be an electrical mix up somewhere..when i turn my key on and the gauges fall into place my heat temp gauge goes all the way past the H then settles down at what i guess would be about 170-180 degrees. any suggestions on what might cause this??
1989 na turbo supra ~ 3ARacing exhaust 2.5" pipe no resinator, sports package
Killa B is offline   Reply With Quote
Old 10-05-2011, 04:39 AM   #2
87hilux7mge
87hilux7mge's Avatar
faulty sensor or gauge id say. id replace the sensor, since its cheap as hell. see if it fixes it, if not, bad gauge. check the wiring too.
Old 10-05-2011, 07:22 PM   #3
interested!
Question heat temp gauge flipped?
Hi!
Have you bled the system of air at the thermostat? .My gauge showed overheating on a cold engine immediately after I had put some new anti-freeze in and topped the radiator up . this was due to an air lock , so the gauge was not reading ANY water at that point and read hot.
Old 10-08-2011, 05:54 PM   #4
It really shouldn't spike to full hot unless the car is on fire or there's a short to ground in the signal wire.... Or it's connected to the wrong sensor or the sensor is shot... Test the sensor as per the TSRM.
Old 10-11-2011, 01:10 AM   #5
Green7mgte
Supra Forum Moderator
off topic, but take a picture of it and make that your avatar.. people would flip ..
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 10-11-2011, 01:51 AM   #6
awesome
Old 10-13-2011, 02:06 AM   #7
Except for 7M owners who would just nod their heads knowingly and somberly. (shed's a single tear)
Old 10-13-2011, 05:28 PM   #8
916MKIIIx2
916MKIIIx2 is on a distinguished road
"Nods slowly" Man that 2hr drive through the mountains was fun! Too bad we couldn't keep driving...
916MKIIIx2 is offline   Reply With Quote
Water temp gauge dead Fredde MKIII Supra 4 05-27-2008 12:40 AM
Heat Consistancy Issues Chambers MKIII Supra 14 04-07-2008 12:52 AM
strange temp gauge activity D_Train MKIII Supra 21 08-25-2007 05:43 PM
Oil temp gauge... what brand?? Caliturbo88 Shops & Part Reviews 0 02-05-2007 09:37 PM
temp gauge 87supraguy MKIII Supra 3 06-09-2005 02:48 PM
