Old 08-16-2011, 07:34 PM   #1
supraturbo_mk3
supraturbo_mk3 is on a distinguished road
Default Wiring issue??
Stupid question....I'm good with the engine but the wiring, I wouldn't know where to start So I'm looking for suggestions on how to diagnose this problem.
My blinkers stopped working all of them no ticking sound at all.
Dash lights went out, temp gauge and fuel gauge stopped working.
I checked all the fuses, they are all good
IF IT AINT A SUPRA IT AINT SH*T!!
87 Supra N/A JDM 7MGTE, 8psi, 2.5inch Exhaust, 18inch Rim's, 255/45/18 rear, 255/40/18 front, 3inch DP, Ported 3inch elbow, Stage 2 6 puck Clutch
95 Eclipse GST 15psi, 3inch Stainless Steel Exhaust, 3inch DP, MBC, 2.5inch Upper I/C piping, Short Throw Shifter, Stainless Steel turbo inlet, Type S BOV (Sold)
89 Supra Turbo, 12psi, 3inch Exhaust, Ebay intake, 2.5inch Upper I/C piping, ARP Head Studs, Stainless Turbo Manifold Tial BOV (Sold)
(Sold)
supraturbo_mk3 is offline   Reply With Quote
Old 08-17-2011, 06:46 AM   #2
The only fuse which will kill MOST of the cluster is the 7.5A Dash fuse. The cluster and the blinkers share NO wiring except for one minor thing; The interior signal indicators (the arrow lights) share a ground with the cluster (On the steering column or the floorboard, can't recall which). Do note that the signals will not work if the hazard switch is disconnected or defective or if the flasher relay is bad.
Old 08-17-2011, 06:33 PM   #3
supraturbo_mk3
lol wow hazard switch was not hooked up
Now to figure out the other problems
(Sold)
Old 08-17-2011, 08:28 PM   #4
Yes I discovered by accident ( as many people do ) that with the hazard plug d/c your turn signals won't activate. Be sure to use Hand signals while diving.
Old 08-19-2011, 03:08 AM   #5
supraturbo_mk3
lol I feel stupid for that but hey how was I supposed to know!........Now my fuel gauge is working to??? Kind of confused on that one......The temp gauge does not work still trying to figure that one out but other then that....Damn she pulls hard and starts every time!!! Loving my supra!
(Sold)
Engine wiring loom? redsupra MKIV Supra 4 12-19-2011 01:05 AM
Wiring issue supraturbo_mk3 MKII Supra 0 08-16-2011 07:26 PM
Engine Run-on Issue gottadiesel MKIII Supra 1 04-02-2009 07:26 AM
