Old 08-16-2011, 12:24 AM   #1
89ST
89ST is on a distinguished road
Default Cam Position Sensor failure
Curious if anyone has had a cps break down instantly. where as one day it worked perfectly and the following day your car wouldn't start and it turned out being your cam position sensor was shot.
Thanks
89ST is offline   Reply With Quote
Old 08-16-2011, 12:59 AM   #2
mirage83
Thanks
I've seen the CPS wiring fail more often than the CPS itself. Having to re-do the wiring for it isn't an uncommon repair as it gets pretty crispy over the years from being that close to the turbo and exhaust manifold.
I'd do a close check of the wiring and plug before I wrote off the CPS.
Old 08-17-2011, 02:39 AM   #3
MJG
MJG's Avatar
I will second mirage83 opinion, wiring on a 20+ year old wire harness is the likely issue.
Old 08-18-2011, 02:58 PM   #4
MA70-3.0GT
MA70-3.0GT's Avatar
And I shall third that haha that wiring gets fair cooked over there!
Old 11-04-2011, 10:19 PM   #5
supraheelfan
supraheelfan's Avatar
supraheelfan is on a distinguished road
Well what do you know , the same thing just happened to me recently. Instead of buying new cps just redo the wiring, huh.
supraheelfan is offline   Reply With Quote
cam position sensor wiring bbullsj MKIII Supra 9 04-06-2011 09:51 PM
Cam Position Sensor JMoses MKIII Supra 4 08-19-2009 05:09 PM
Idle Position Sensor Problem White87Turbo MKIII Supra 4 06-20-2006 05:38 AM
