Old 08-09-2011, 04:46 AM   #1
dylansword
dylansword is on a distinguished road
Default Help me fix my hesitation and cut out!
I've got an 87 turbo. At about 3-5k rpms, it either hessitates ot completely cuts out.
It has the translator pro, aftermarket IC and piping, and full 3in exhaust.
It has new water pump, tps sensor, o2 sensor, spark plugs and wires.
The car came with the translator, because the pervious owner suspected the maf was going out. So I installed it and the car still has hessitating and cutting out problems.
Also, it idels high (the adjuster screw is all the way out), misses a little, and runs rich.
Any suggestion, or things to check will be greatly appreciated!
dylansword is offline   Reply With Quote
Old 08-09-2011, 11:47 AM   #2
El Supracabras
El Supracabras's Avatar
DIAGNOSTIC CODES. Did you check for any yet? Do it now.
The MAFT Pro, is it set to run a MAF or MAP sensor?
Old 08-10-2011, 12:40 AM   #3
dylansword
I just checked for codes. There is none. And it is set for maf
Old 08-10-2011, 03:17 AM   #4
dylansword
I just replaced the fuel filter and turned the boost down to 7 psi and it is still cutting out.
Could the ecu be cutting fuel too early?
Old 08-10-2011, 03:27 AM   #5
dylansword
Also, when the car is in neutral, it revs up and spools with no problem at all. And as well as when I peel out, and the tires are spinning, it doesnt cut out..
Old 08-11-2011, 03:26 AM   #6
El Supracabras
If there are no codes present, you might just have a boost leak. They can be tricky to find. It sounds like it's only happening under boost. You can also check the spark plugs if you haven't changed them in awhile.
Old 08-11-2011, 07:24 AM   #7
Do you have a wideband installed? Is the AFR spiking past 20:1 when this happens? Have you done any tuning? If so, what?
Old 08-11-2011, 05:51 PM   #8
dylansword
I don't have a wideband, but I will be getting one. (Recomindations are valued). And as far as tuning I have the maft pro, and everything is set to what the manual says.
Old 08-11-2011, 11:44 PM   #9
The manual doesn't cover how to tune or any significant fuel adjustments... look to see if the mainscale is anything other than 0 and check to see if the fuel "tune" maps are all zeroed out or not. I know you have a MAFT Pro and it's safe to say I know a tiny bit about them.
Old 08-11-2011, 11:59 PM   #10
dylansword
I don't have the manual for the translator, the car came with everything but that when I bought it. I found everytging I know about it online.
So, could you breifly explain the main scale adjustment? I think I know which ones your talking about for the fuel tune ones.
Also, when the car is running, the tps, o2, and spark all show 0 and don't change... should they?
