Old 07-31-2011, 04:54 PM   #1
my89Supra
my89Supra is on a distinguished road
Default Stripped Exhaust studs
Looking for best solution to repair stripped exhaust studs. I see DriftMotion sells a helicoil repair kit and another company called Time-sert sells thread repair inserts.
Anyone have experience with either of these or have an alternate suggestion ?
Also, is it possible to remove the exhaust manifold with the turbo intact (disconnecting oil and water lines of course).
Thanks for the help.
my89Supra is offline   Reply With Quote
Old 07-31-2011, 05:45 PM   #2
El Supracabras
El Supracabras's Avatar
Yes they work, but the material on the head is sometimes beyond being able to hold even a heli-coil. The drift motion kit is nice because they did the shopping for you. You could buy it yourself all separately but I doubt you'd save much. There really is no other alternative beside replacing the head.
You prolly could leave the turbo on but I would take it off and give it a good cleaning and inspection while it's easy.
Old 07-31-2011, 06:44 PM   #3
my89Supra
Default Exhaust studs
Thanks for the feedback.
The DriftMotion kit includes oversized studs so I should be okay there. I'll probably see about rebuilding the turbo if only to replace the oil seals as the car burns oil when the turbo kicks in hard. Probably a good idea to play it safe and have the exhaust manifold shaved too.
Thanks again for your help.
Old 07-31-2011, 06:47 PM   #4
907mge
907mge's Avatar
http://cjsupra.kendra.com/Helicoil.html
Old 07-31-2011, 06:54 PM   #5
my89Supra
Fantastic, thanks!
Old 08-01-2011, 12:52 PM   #6
Green7mgte
Supra Forum Moderator
IIRC the kit offers acouple different sizes? maybe not, it's been awhile since I read on the subject. Altho I do remember the guy who makes them said he only put a 5 dollar mark up on it. or you could do what I did for a stripped exhaust bolt.. concrete lag bolts. what? don't look at me like that. ....
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 08-01-2011, 01:09 PM   #7
El Supracabras
lol...concrete lag bolts.... nice!! Do they come in grade 8?
Tags
driftmotion, exhaust studs, stripped studs, time-serts
stripped out exhaust manifold stud robertsws MKIII Supra 3 07-31-2011 04:38 PM
Exhaust system & components Krem MKIII Supra 6 05-27-2010 12:35 PM
Exhaust for 7MGE XtreeX MKIII Supra 19 03-25-2010 01:39 AM
exhaust question (not in exhaust faq) sd88supra MKIII Supra 21 11-28-2006 10:52 PM
