Old 07-17-2011, 11:13 PM   #1
Life is Supra
Life is Supra is on a distinguished road
Default turbo and intercooler
Hi guys,maybe I have a stupid question(for u)but I must ask.I plan to rebuild my ct-26 very soon and with what I must clean intercooler core and pipes because there was an oil leak on turbo.Thanks in advance
Life is Supra is offline   Reply With Quote
Old 07-18-2011, 02:16 AM   #2
kerosene is what you will use.
Old 07-19-2011, 01:59 AM   #3
mirage83
Couple of things...
First, not sure of your background or equipment, but unless you have some precision, high-end equipment rebuilding a turbo (CT-26 or any other) you're asking for serious trouble. Given the very high RPM's these things spool up to, the rotating assembly has to be balanced EXTREMELY well to avoid damage or destruction to the turbo and potentially the engine as well. I sincerely recommend sending it off to a reputable company to rebuild it for you unless you have the experience and hardware to do it.
For cleaning your intercooler and pipes, you can even use gas so long as you dispose of it safely afterward. Just for the record though, the type of bearings and seals used in the CT-26 will always allow some amount oil to pass through into the intake pipes and eventually accumulate in the intercooler. That's the case even on newly rebuilt units, so don't panic when you see it later down the line. Unless it's really a LOT of oil, it's normal.
Old 07-19-2011, 08:41 PM   #4
I just assumed he was taking the turbo to a dealer.. thats what I would do. or send it into driftmotion.
Old 07-19-2011, 09:05 PM   #5
mirage83
Driftmotion, seriously. And go ahead and do the 57 trim upgrade while he's at it.
I just get real uneasy when someone says that he's going to rebuild his turbo. Those things spin up too fast for comfort if you're not 100% sure of the balance.
Old 07-19-2011, 09:37 PM   #6
you need a machine to balance them properly I think he was thinking more along the lines of re doing the seals. I think they sell something like that on ebay. I just don't fiddle with it.
intake and turbo intercooler diagrams CanadianBak'inSupra MKIII Supra 9 07-09-2010 02:56 PM
Which Aftermarket Turbo? Intercooler? RoLLiN MKIII Supra 1 06-10-2006 06:57 AM
