Old 06-30-2011, 03:54 AM   #1
rodney120985
rodney120985 is on a distinguished road
Default New Supra owner
I just got my first supra it is a 96.5 N/A, plannin on doin a 2JZ-GTE swap in it or possibly a 7M-GTE swap depending on money. Right at this moment I am tryin to get all the things that are on it up and working correctly. I know I have to redo the interior it is shot, main question I have with it is where to find a dash pad mine is cracked and missing pieces! It has the fog lights on it but at the moment they do not work I have replaced the bulbs and tested to see if they get power to the light themselves and they do not, the fuse it good, so I was wondering if anybody else has had this problem. Any help would be a great help.
rodney120985 is offline   Reply With Quote
Old 06-30-2011, 05:22 PM   #2
El Supracabras
El Supracabras's Avatar
Welcome to the supra world. I assume you meant 86.5 not 96.5. All of the problems you are experiencing with yours are pretty much standard when you first get one. Its part of the ownership experience to slowly put the whooped, ill maintained car back together. 7M is a great engine but if your going to swap it just go straight to the 2jz, you will likely be happier in the end and it may increase the value of your car (which is hard!).
FYI, the headlamps must be on for the fogs to work. Not sure if you knew that. Otherwise search this forum as well as the internet, there are numerous write ups regarding diagnosing, repairing and modifying the fog lamp system. Good luck.
Old 07-01-2011, 04:30 AM   #3
rodney120985
yea i did mean 86.5, i think i will end up goin with the 2jz swap. i got the car to do a good rebuild and build up. Just have to try to find the interior stuff i need to start with. i will have to try and find a fourm on here about the fog lights. thanks for the help on this and hopefully more to come.
Old 07-01-2011, 12:43 PM   #4
El Supracabras
Don't be discouraged to do a rebuild if thats what you want. I suggested the 2jz swap simply because in the end it will likely cost the same or close (if you plan on doing the 7M right). Salvage yards, craigslist, ebay and the "for sale section" of forums are some of the best places to look for used parts like your dash.
This might help with the fogs.
http://www.cygnusx1.net/supra/Librar...l.aspx?S=D&P=1
Old 07-01-2011, 02:13 PM   #5
El Supracabras
Here is another nice write up once you get the fogs working again. This gentleman was nice enough to take pics so you can see where everything is at. This mod will allow you to turn only the fogs on.
http://gallery.sanitylapse.com/v/sup..._9406.jpg.html
Old 07-01-2011, 06:24 PM   #6
rodney120985
thanks for the info on the fog lights, did some searching last night and found some stuff on the fog lights that hopefully will help as well. I did find the for sale section will make for find the dash pad a lot eaiser.
Old 07-01-2011, 09:54 PM   #7
907mge
907mge's Avatar
You will have lots of fun if you replace the dash pad. They suck to get out. But if you do end up replacing it then you may want to consider doing the heater core at the same time.
Old 07-01-2011, 10:53 PM   #8
rodney120985
yea from what i have read it looks like the dash is a big pain in the a$$. thanks for the input about the heater core wouldnt of thought of that.
New supra owner (with a few questions) manrique112 MKIII Supra 16 04-26-2011 12:25 AM
New Supra owner jbl1500 MKIII Supra 12 01-20-2010 02:06 AM
New supra owner (not running) here What to do next Gengus MKIII Supra 1 11-12-2007 03:46 AM
New to this forum(not a supra owner though) Supra spotted in tucson. z33 DaRkNeSs Off Topic Forum 5 08-28-2006 11:16 AM
